I'm wondering the same thing. I've thougt of going with eliminators, but i may just remove the resonator and replace it with straight pipe or a x-pipe.
Yeah I have seen the shootouts but I am still wondering if the stock 2.75" LT1/4 Cat-back is actually 2.75" through out the whole system. I heard that the resonator internal tube DIA is around 2" if this is the case.. I shoudl switch back to my Flowmaster Cat-Back then
It's seems it was bigger than that when I took pics of it. Did you allready install the one I sent ya ? I did send it to you didn't I ?
I see if I can find the pics & post them.
Neal
Yeah Neal I got it, funny thing it is still in the package you sent it too me.. LOL. I will open it up tonight and look. I think I will end up swapping the mufflers, as long as the resonator is 2.5" inner DIA.
there is an exhaust shootout in corvette fever awhile ago with a g/s and I believe the dynomax system just replaced the mufflers and picked up ~8 or so rwhp.
Is any of that article available online, or anywhere else for looking at?
I have my old stock LT4 exhaust system in my garage. The system is 2.75" OD except the inlets/outlets to the resonator necks down to 2.5" and the inlets to the mufflers neck down to 2.3". My Corsa is 2.75" OD all the way.
Re: LT4 exhaust restriction questions> (silver & red CE)
Eric
Yeah sorry I meant 2.75" That was about an 1" from the actual resonator (I have one hacked from the exhaust). Then it is straight through.. I know the mufflers neck down, I can see that without a doubt.
But as far as I know.. Corsa is 2.5" just like the Flowmaster and I know that the stock tube are bigger in some areas compared to the flowmaster system I have in the garage.
I am also not arguing the idea that an aftermarket exhaust does not flow better, I just would like to see how well the stock exhaust can flow by just changing a few pieces..
...But as far as I know.. Corsa is 2.5" just like the Flowmaster and I know that the stock tube are bigger in some areas compared to the flowmaster system I have in the garage....
I don't know anything about the Flowmaster system, but I can assure the Corsa is 2.75" OD (outside diameter) all the way. When speaking of exhaust most people refer to the ID (inside diameter) which for the Corsa is 2.5" all the way.
Eric
So just so I understand correctly.. if you by Exhaust clamps for the Corsa do you get 2.5 or 2.75?
I don't know because the Corsa system comes with really nice clamps from the factory, hence I haven't purchased any. But when I pull out my venier calipers and measure the Corsa, all the pipes are 2.75" OD. All the joints are flared so the minimum OD throughout the catback is 2.75". The OD of the flared joints is 3.0". Hope this helps.
Eric
Eric
yeah it does THANKS.. Last question.. did you notice or have any info that shows you got a gain from stock to the Corsa?
I know that TNT is going to post the exhaust info from Corvette fever.. but I would like other input as well
...yeah it does THANKS.. Last question.. did you notice or have any info that shows you got a gain from stock to the Corsa?
To be honest, I have my doubts, but in the last few weeks there's been a couple of threads where Corsa owners have posted before/after dyno graphs. The graphs show real gains in average and peak HP, something like 14RWHP peak. I was surprised because I didn't notice any difference other than the great sound. I haven't been to the strip since I installed it, and now I've done too many mods now to give a real report.
OK gang, here we go. Its in the June 1998 issue of Corvette Fever, page 19 - 23 and the testing was done by Jim Van Dorn of automasters in california @ K&N's dyno facility.
A stock 1996 Grand Sport put out 299/307 in hp.torque.
Here are the results in horsepower/torque
B&B Triflow 310/310
Dynomax 304/310
Borla 304/310
Flowmaster 306/309
Powereffects closed position 299/308 & open position 311/313
Also the cost of these systems is something to look at when comparing the power to cost ratio. The list prices are based on the print date of the article.
B&B $1275
Dynomax $229 (mufflers system only)
Borla $1795
Flowmaster $837
Power Effects $1599
Some other intresting test results include de @ idle & warm and then crusing @ 70mph in 6th gear:
Oh yeah, why is the magazine you are looking for always at the opposite end of the pile?
Enjoy all!!!
THANKS TNT,
I have that at home too, This is why I cannot see spending between $700-$1200 for an exhaust system for those kind of gains. Granted that on a modded motor there will be more gains, but still. I found a set of mufflers I may try with my catback I have now.. We will see
Pretty much confirmed what I had suspected. B&B makes excellent power, is large enough (3") to accomodate more power later , aint cheap - but not the most either, is loud but no THAT loud.
I still have yet to hear one from in the car to see how badly it resonates , but coming from a Cobra with shorties, off road H pipe (no cats), and Flowmaster catback , I somehow dont think it will sound that loud.
Bang for the buck with Magnaflow is great but I want a complete high quality system, not just the mufflers. I also think the B&B's look the best IMHO. I do , however like the fact the the PE's are adjustable and they sound AWESOME, they are just too expensive and heavy.
From what I have read about Corsa's , which were not in that test, they generally seem to yeild 7-12 rwhp which puts them right there as well(although who knows what they would yeild on the same day same dyno , side by side with the others). They are relatively cheap listing around $995, and they are relatively quiet and do not resonate. The only down side to me is the 2.5" tubing may be a bit restrictive for an engine putting down over 400 rwhp (which is where I am going with this car). :seeya
Eckler's lists the B&Bs for $1229. I found a place on the WEB that sold them for $100 less. Eckler's states that they will meet any price lower than theirs. So I told them I found the B&Bs at a cheaper price. They matched it. Funny thing is that they didn't even ask me where I found the lower price. Could I have said I found them even cheaper? Don't know what their pain threshold might be. Just a hint if you decide to go through Eckler's.
