Priming LT1 Oil Pump
Old Jul 17, 2002 | 04:42 PM
STL94LT1's Avatar
STL94LT1
Default Priming LT1 Oil Pump
After an engine rebuild on a LT1, how do you prime the oil pump before starting?
Old Jul 17, 2002 | 06:04 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Priming LT1 Oil Pump (STL94LT1)
Use an oil pump tool. I have one by Moroso I got from Summit Racing. It is basically a long drill bit drive shaft you put into the top of the oil pump and run a drill to spin the pump. You have to do this before installing the intake to the engine.
Old Jul 17, 2002 | 06:08 PM
STL94LT1's Avatar
STL94LT1
Default Re: Priming LT1 Oil Pump (Vette92)
OK thanks Chris, I didn't even think of priming the oil pump before the intake was installed.
Old Jul 17, 2002 | 06:13 PM
Robey5's Avatar
Robey5
Huh, I did not think that you had to prime these prior to installation, but I am far, far away from that concern as of right now. What happens if you don't do this?
Old Jul 17, 2002 | 06:20 PM
GlockLT4's Avatar
GlockLT4
Default Re: Priming LT1 Oil Pump (Robey5)
bad things.. just be sure you do it.
[Modified by Glock'94, 4:20 PM 7/17/2002]
Old Jul 18, 2002 | 10:44 AM
Eric Fischer's Avatar
Eric Fischer
Oil starvation could lead to spun bearings. May not happen on a rebuild because you are protected by the assembly lube. But it did happen to me when I put the hot cam in. I put the hot cam in, failed to prime the oil pump and 10 miles later the rod bearings run spun.
To do it right you need the correct tool (don't just use a socket attached to your drill). The tool seals off the galleys in the distributor. If they are not sealed off most of the oil will bypass through those galleys.
Old Jul 18, 2002 | 11:06 AM
ZylaRace's Avatar
ZylaRace
Default Re: Priming LT1 Oil Pump (Eric Fischer)
AZone has a pump primer rod as a loaner.
Make sure your drill is spinning clockwise.
Spin it till oil comes out the push rods.
[Modified by ZylaRace, 9:07 AM 7/18/2002]
Old Jul 18, 2002 | 11:08 AM
Robey5's Avatar
Robey5
Huh...OK. I would not have done that had I not known. I will see if I can borrow dads, after he re did his 911 C4 motor...but I don't remember him doing that...
Can I get one of these at A-Zone?
Old Jul 18, 2002 | 11:31 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I have never primed the pump when just changing cams (and I have done several). But ALWAYS do it when the pump is new or the engine has not been fired before.
Part number MOR-62200, $13.95 from Summit Racing is the oil primer I used.
Chris
Old Jul 18, 2002 | 06:47 PM
Eric Fischer
Chris
Me, either. I have done at least 10 cam changes before (on Fords though). But it doesn't hurt to do it when changing a cam, so I no longer skip this step.
To Priming LT1 Oil Pump
