Engine pulsating at low RPMs?
Old Apr 3, 2014 | 06:28 PM
DanielRicany's Avatar
DanielRicany
Default Engine pulsating at low RPMs?
Hello, I have a 1985 Corvette with a Miniram, 58mm throttle body, flat tappet zz409 camshaft, AFR 195 heads, Hedman Longtube 1 5/8" headers, 1.6 roller rockers, true dual Dynomax exhaust, with a bunch of other smaller modifications.
Anyway, it feels like I have a subtle pulsation under 3k RPMs. I also have a subtle idle surge and I think that's because of a small vacuum leak.
If I got WOT it doesn't feel like it is pulsating, if I bring it above 3k RPMs, it doesn't feel like it is pulsating. It feels really strong at WOT, doesn't feel like it is running on 7 cylinders.
Ignition wires were replace 6 months ago, and within the passed 2 months I've replaced the plugs, distributor, coil, ICM, pick up coil, cap, rotor, and have good compression.
All cylinders pass a power balance test.
It feels like a misfire but I don't know if it is.
Could being under a 1/4 tank of gas cause this?
Could a vacuum leak cause this?
Can too much timing cause this?
Is it the camshaft causing this?
Spark knock or anything causing this?
Thanks.
Old Apr 3, 2014 | 07:05 PM
ToniJ1960's Avatar
ToniJ1960
Im watching this one myself, my 84 seems like it has a heartbeat when it first starts sometimes. The idle is smooth `underneath` it.
Old Apr 3, 2014 | 09:19 PM
TimV SR's Avatar
TimV SR
My '85 had an upgraded cam installed by the previous owner before I bought it in 2002. It often surges at idle when hot and I always thought it was "loping". Never stalled or caused any other issues.
Old Apr 3, 2014 | 09:24 PM
John A. Marker's Avatar
John A. Marker
I would suggest that as it is at idle you pull one injector plug at a time to see if there is a noticeable difference. If there is a difference by pulling the plug....you should be good on the cylinder. If there is no difference. You probably found found the cylinder in question.
If you find a cylinder that is bad with this test, then check to see if your getting the injector to fire. I believe that a noid light is used to test this.
Old Apr 4, 2014 | 10:22 AM
leesvet's Avatar
leesvet
has this thing EVER been "tuned" for all this hardware that's been installed?
Old Apr 4, 2014 | 11:05 AM
powerpigz-51's Avatar
powerpigz-51
This noise.......Kinda like a helicopter? A low woop woop woop......
Old Apr 4, 2014 | 11:35 AM
MrWillys's Avatar
MrWillys
Not enough timing, so try 30 to 34 degrees at idle, and upwards of 2000 as it comes off throttle and vacuum drops. This added timing will help smooth things out.
I found the snipping tool, but can't get it to the screen, or I'd post up a table for you.
To Engine pulsating at low RPMs?
