84 head replacement
Old Apr 4, 2014 | 12:27 PM
Bridges77's Avatar
Bridges77
Default 84 head replacement
I have an 84 that has a cracked head. I can get a set of heads casting number 14022601 for free I know they are supposed to be 305 ho heads will they work for now? It was already carbed when I got it. Everything else is stock. Please no aluminum upgrade comments just tying to get this thing running it needs so much tlc. Thanks
Old Apr 4, 2014 | 03:41 PM
cohocarl's Avatar
cohocarl
601's I think are tiny 53cc combustion chambered heads. Do you know what heads you are taking off? How much lift your cam has? I think the stock 84 heads were 76cc. (I could be wrong) So putting 53cc heads on there might not be such a good idea. Even if piston/valve clearance would be ok, if it's at around 9:1cr w/76cc heads, putting 53's on there would bring it up to the 11.5 to 12:1 range.
Old Apr 5, 2014 | 08:44 AM
ghoastrider1's Avatar
ghoastrider1
rebuilt vortec heads can be found for around 300 bucks. Manifold to fit them, another 100, 150 bucks. improved performance, priceless.
Old Apr 5, 2014 | 01:44 PM
corvettenorway's Avatar
corvettenorway
Old Apr 5, 2014 | 09:42 PM
Bridges77's Avatar
Bridges77
Good info thanks guys.
To 84 head replacement
