I have been looking for a new SFI approved bellhousing for my 95 C4 manual 6 speed. I have looked at all the regular places Quicktime, Summit,
Jegs and have not had any luck. Does anyone know of a supplier that sells the bellhousing? If anyone know let me know.
Quicktime RM-6039 will work. You would need to change to a hydraulic release like maybe the Mcleod 1345 with their dual-disc, the Mcleod 1345 brearing or maybe someone else's clutch and a different hydraulic release. Maybe Ram but the Mcleod with the ZF is a dedicated ZF install to the guide tube retaining ring.
I already have the Mcleod dual disc set up it came with all the extra parts as a kit. Thanks
You've got the 1345 bearing that attaches to the ZF guide tube? Do your measurements just like they mention and they'll replace the shims for you until you get an install that is correct. I talked to them regarding a set up and they were first class. You need to speak to them though and not any of the third-party resellers.
I believe the 6039 should come with the engine plate. I believe I've seen someone mention that theirs didn't and I believe that might be an error. I'd make sure.
If you've only got a 1300 series bearing and NOT the 1345 you want the 1345!
