oil temp sensor
Old Apr 6, 2014 | 07:56 AM
tideferi's Avatar
tideferi
Default oil temp sensor
hi...
I don't remember where the engine oil temp sensor goes.....I have two hole on the filter adapter...one can touch the oil and the other one pass through the block and finish just between the ring gear......I check some book and it says goes in the hole pass through the block and the other one its a plug going there.......im not sure........thanks and excuse my bad English........c4 1984 automatic
Old Apr 6, 2014 | 06:54 PM
vetteoz's Avatar
vetteoz
In the block hole above the oil filter
Old Apr 6, 2014 | 08:55 PM
tideferi's Avatar
tideferi
thank you sir......
To oil temp sensor
