Mild mods and an AFPR?
My car had an AFPR, K&N and the open front airbox when I bought it, along with a tranny swap. I don't think there's any other mods. No rockers, stock throttlebody, runners, etc. Nothing ported. It was running at 45 PSI, but I had a really rich smelling exhaust. Normal?
Anywase, I needed to get a new throttlebody and I had a 58mm plenum sitting around so I bought a 58mm Holley throttlebody.
My question is, I feel like 45 PSI was WAY too much for what it was when I bought it. But how much PSI do you guys think I should be running now with the 58mm plenum and throttlebody? Still the stock runners. Those are going to Edelbrock Hi-Flows later.
That said, you should check the BLMs to make sure the ECM isn't "hitting the stops". The BLMs are limited and if the ECM hits a limit then it can't compensate any further and you will run rich or lean depending on which one you hit.
When the ECM is running in open loop mode (cold coolant or high throttle openings) then it is dependent on the injector constant and fueling tables. If the injector constant is not changed and/or the fueling tables are not adjusted to compensate for the modified injector flow rate then you can run rich.
