Supercharging a 1995 LT1
In Internet slang, a troll is a person who sows discord on the Internet by starting arguments or upsetting people, by posting inflammatory, extraneous, or off-topic messages in an online community, either accidentally or with the deliberate intent of provoking readers into an emotional response.
You have consistently been insulting to me on this thread and my other one. On here you have called me "lazy" because I have not checked for spark.
1) You don't know me or my schedule. You may have hours a day to throw around on whatever you want. Not everybody has that luxury.
2) Checking for spark per your instructions requires 2 people. So now I have to find another person who's schedule lines up with mine.
As for your misplaced definition above, I guess we could all say the same things apply to you. This was a discussion about "LT1 bottom ends", opinions on both sides. Only problem with your opinion is that there are errors that facts can clarify.
" I have tried pulling one and grounding the side, and there is spark, but I'm not sure it is enough.
I tried to help you and you later said:
" I just don't want to dig around in stuff if I don't have to."...so...
It's pretty obvious to me that you don't "get" how engines work or what they're made of. Your own car doesn't run -for example, and you thought it might be because the "spark plugs had backed out a little" (?). So now, you're taking examples where people have run LT1's at RPM's far higher than the factory rev limiter, and then claiming that "You cannot possibly say LT bottom ends are as strong as other SBCs."...which in fact is completely untrue and LT1's bottom ends are every bit as strong as other SBC's...they're just getting rev'ed much higher in this application and there is a consequence to that. The OP is asking about supercharging an LT1. You area saying that it shouldn't be done b/c guys spinning 6500 stock bottom LT1's have had spun bearings. Can you see how what you're saying is irrelevant and misinformation? I hope that you can. I (and others) are saying that you CAN do it, keep the boost reasonable, give it a good tune, and stay w/in the factory 5850 RPM limit. Share your opinion that you wouldn't boost an LT1, but saying that it's not as strong as other SBC....that is wrong.
With regard to my comment about your links with the spun bearings, vs "thrown rods", that was in response to your original claim that;
"LT1s throw rods fairly easily." You then posted three links. 2 had spun bearings, not "thrown rods".
Sorry that you're so sensitive that facts are considered "rude" to you. That would suck.
Right...I'm the one "throwing insults", here? You've called me a "troll" multiple times, which I am FAR from a troll here. I called you lazy b/c you admitted in your other thread that you would rather pay a tuner to fix your problem (which wasn't going and didn't fix the problem) rather than spend 5 minutes to do a basic check of something that you yourself had expressed concern over.
It's pretty obvious to me that you don't "get" how engines work or what they're made of. Your own car doesn't run -for example. But you're taking examples where people have run LT1's at RPM's far higher than the factory rev limiter, and then claiming that "You cannot possibly say LT bottom ends are as strong as other SBCs."...which if fact is completely untrue and LT1's bottom ends are every bit as strong as other SBC's...they're just getting rev'ed much higher in this application and there is a consequence to that. The OP is asking about supercharging an LT1. You area saying that it shouldn't be done b/c guys spinning 6500 stock bottom LT1's have had spun bearings. Can you see how what you're saying is irrelevant and misinformation? I hope that you can. I (and others) are saying that you CAN do it, keep the boost reasonable, give it a good tune, and stay w/in the factory 5850 RPM limit. Share your opinion that you wouldn't boost an LT1, but saying that it's not as strong as other SBC....that is wrong.
I don't believe that I have called YOU any such things.I have no need to PM you to argue. I'm pointing out the facts for the unwitting who have the misfortune of reading your misleading posts in this thread. No need to PM...all the info is right in this thread.
take a look in your control panel, select "edit Options", scroll down and turn off (ie: select) "Disable Infinite Scroll" and also turn off (ie: select) "Disable Related Threads" 2 features that have caused lots of embarrassment and the bringing back to life threads that are long dead, such as this one, which is 8 years old.
Now as you play, the first to go will be the stock pistons and rings. You will then choose to increase engine size to 383 cu in, lower the compression ratio to about 9.2 and add headers. Then of course there's the fuel system to consider. IT NEVER ENDS.
When the project is completed you'll have a very expensive, supercharged LT 1 producing 598/600 rwhp @ 5900 rpm which you can't do much with DUE TO LACK OF TRACTION.
If your interested in the finished product, contact me in FLORIDA. I can use the garage space.
The OP (original poster) who put this thread up 8 years ago ??????
The guy who brought an 8 year old thread back to life stating he has 3 LT1's that he drives hard ?????
Inquiring minds want to know.
during a forum software upgrade. Whoever thought that up should be flogged.
INCLUDING DRCOOK (ie: me) so I have been guilty of it myself. Nowadays I watch very closely the dates of posts
It is harder to see if you are accessing the forum on a phone.
the p315/35r17 toyo r888r’s were hooking the prepped surface even in first, but ive had them break loose at high rpm on the street in cooler temps
