*&^$%# GEARS
Old Jul 18, 2002 | 04:11 PM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
Default *&^$%# GEARS
I have been trying for almost 2 weeks to find out if I have Dana 36 or Dana 44 gears with the G44 & G92 option on a 96 LT1. I have called all 5 GM dealers in my area, NO HELP. I called the GM customer service line, who then put me on the phone with the same dealership who could not help me. The Dealership did make more of an effort this time around called GM Techline who told him that GM did not put Dana 36 or Dana 44 in Corvettes. They put something called a CQW Dana. I asked him what the @&(#$ was that and he said he did not know. :mad .
Is there anyone out there, who had the 3.07 G44 & G92 codes that upgraded to the 3.73? If so what gears did you get. Please someone help me.
Old Jul 18, 2002 | 06:01 PM
Untouchable00's Avatar
Untouchable00
Default Re: *&^$%# GEARS (UB2 SLOW)
Did you post on the c4 section??
Old Jul 18, 2002 | 11:35 PM
GS345's Avatar
GS345
St. Jude Donor '11
If its a 96 LT1 its a DANA36. LT4 DANA44
Old Jul 19, 2002 | 11:24 AM
silver & red CE's Avatar
silver & red CE
LOL, you found the right place to ask.
Check out these threads: http://forums.corvetteforum.com/zerothread?id=343901 http://forums.corvetteforum.com/zerothread?id=343901
Also there's a sale on a set up rear end from ZIP http://store.yahoo.com/corvetteforum/zip-su-702-gp.html
Eric
Old Jul 19, 2002 | 12:47 PM
ddsovy's Avatar
ddsovy
I'm told Convertibles had Dana 44's and Coup's had Dana 36's, (at least for the early years)...couldn't tell you why.
Old Jul 19, 2002 | 01:38 PM
silver & red CE
Default Re: *&^$%# GEARS (ddsovy)
No, this isn't right. All 84s had Dana 36, for 85-96 all manual trans cars have the Dana 44, all autos have the Dana 36.
So 96 LT1 means Dana 36 (because the 96 manual trans only came with the LT4).
(edited due to very confusing typo)
Eric
[Modified by silver & red CE, 1:04 PM 7/19/2002]
Old Jul 19, 2002 | 02:02 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: *&^$%# GEARS (silver & red CE)
So 96 LT1 means Dana 44 (because the 96 manual trans only came with the LT4).
Eric
dont you mean 36?? 96 LT1=auto=36
Old Jul 19, 2002 | 02:26 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Auto = 36, Stick = 44. (For all C4's) (EDIT, I guess except for '84 if the above is true)
Whatever gear ratio is in the carier is also stamped on the bottom side. If you can get under the car, you can read it yourself. This stamp will be accurate if the gears have not been changed by a previous owner. The previous owner could have also changed the 36 to a 44 if they were into drag racing.
[Modified by Vette92, 12:27 PM 7/19/2002]
Old Jul 19, 2002 | 02:38 PM
UB2 SLOW's Avatar
UB2 SLOW
Default Re: *&^$%# GEARS (Vette92)
I crawled under the car already and I got this off of it.
605490-2 2025
10163876
3.07 43-14
26 Apr 96
According to Pace Performance, if you have the G44 & G92 codes, you cant tell if you have a D36 or D44 unless you remove the cover. IThanks for the help, I think I am going to go with the D36, thats what I seem to have more replies on than D44. If its wrong, hey thats why they have refunds right.
[Modified by UB2 SLOW, 6:40 PM 7/19/2002]
Old Jul 19, 2002 | 02:41 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
If it has 3.07 gears, then it is a 36.
Old Jul 19, 2002 | 02:43 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
You can also tell if it is a 44 or 36 by the number of bolts on the back. The 36 has 6 whereas the 44 has only 5.
Old Jul 19, 2002 | 03:03 PM
silver & red CE
Default Re: *&^$%# GEARS (MarkLT1)
Eric
oops, could we make this more confusing, yes you're right, i'll edit my post!
Eric
Old Jul 19, 2002 | 04:41 PM
ConeKLR's Avatar
ConeKLR
Can't believe you did not ask here first.. we know more than any GM rep. :lol: :cheers:
To *&^$%# GEARS
