I gotta get this thing out.....
If not, could someone describe what you had to loosen/remove?
All halfshafts, knuckles, and exhaust have been removed.
I did this over the winter. I pulled the driveshaft and c-beam, the spindle rods (the aluminum members from the diff to the knuckles) and the tierods from the diff to the knuckles. I loosened/removed the u-joints at the half shafts/diff. Now the only thing holding the diff in place is the two bolts on the frame/batwings. It's much easier to drop the batwing/diff and remoove the batwing cover with the diff off the car. If your changing the gear you'll have to seal the batwing cover onto the diff after the gear swap, I can't imagine how to do a good job of sealing the case with the batwing on the car.
While I had the diff out I installed a drain plug on the diff case, much easier to change the lube with it. I also installed poly bushings on the batwing/body and the spindle rods. Very nice!
Eric
Make sure you use a jack or 2x4 to support the tranny. If you dont support it, you could crack your distributor later on.
Remove the driveshaft by undoing the spiderstraps on the differential end of the shaft.
Remove the 4 bolts (2 on each end) that hold the C-beam onto the tranny and differential. Use a pry bar and work the C shaft off the car, it will take some time, but be paitent, it will come out. Make sure you dont pry on the output shaft of the tranny
Use a jack and support the differential, undo the batwing bolts, and the diff will fall basically fall out. Have someone helping you, one of you to hold the diff another to operate the jack.
The diff is sealed with RTV silicone, and make sure everything is super clean before you reassemble it. (use acetone to wipe off the mating surfaces, make sure all sealent is gone etc...)
Thats it, install is reverse of removal :D
Have fun, i did a total swap in 2 days including part hunting (bolts were stripped on my replacement diff :U ) Really sucked
have fun...
Milan
BTW, does anyone know of a good online step by step procedure for swapping out the gears (much like Scorp's U-joint replacement procedure)?? I will be performing my first gear swap with an experienced friend, but I would like to see what is out there for information. I also plan on taking lots of photos and will of course share once completed.
