MAP sensor
Old Apr 19, 2014 | 02:28 PM
Charles.rogers1's Avatar
Charles.rogers1
Default MAP sensor
So I'm about to take the 96 procharged in for a tune, and I'm curious, are there aftermarket better manifold absolute pressure sensors? should I be looking into getting a better one (if they exist) would it make it that much easier and result in a better tune??
Old Apr 19, 2014 | 02:37 PM
STL94LT1's Avatar
STL94LT1
Unless you're going over 15lbs of boost your stock 1 bar MAP should work just fine.
Old Apr 19, 2014 | 02:38 PM
Charles.rogers1
ah okay! all I needed to know cause I'm only going 6-8lb
To MAP sensor
