1989 corvette accelaration
Old Apr 19, 2014 | 07:09 PM
skysurfer2000's Avatar
skysurfer2000
4th Gear
Default 1989 corvette accelaration
I have a 1989 chevrolet corvette with accelaration issues
When i accelerate from under the hood everything sounds normal and rpms increase regularly
When i accelerate from the pedeal the cars stalls the rpms are not regular
I took a picture of a device that is loose and attached to the accelerator chains
Old Apr 19, 2014 | 07:22 PM
DanielRicany's Avatar
DanielRicany
Something Is Wrong With The Cable
Old Apr 19, 2014 | 08:12 PM
skysurfer2000
4th Gear
I can't upload the picture there is a device connected to one of the chains that's loose hanging in the engine compartment
This device has the chain going inside and a cover, this device has some wires and connectors I guess it controls the rpm the acceleration
I wish so bad i could upload the picture would be so easy to understand i really think that's the problem
Old Apr 19, 2014 | 08:20 PM
DanielRicany
When You Reply On The Advanced Reply Page, Scroll Down A Little And Click Manage Attachments. You Will see A Window Open And Display About Five Available Spots For Files To Upload. Click Choose And Select Your Picture. Then click Upload. Close The Window, And Submit Reply.
Old Apr 20, 2014 | 12:00 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There should be no "chains" connected to the TB.
There are three cables:
-accelerator cable, has a retainer clip at the throttle plate lever
-cruize control cable, has a retainer clip at the throttle plate lever
-TV cable, has no retainer clip but the end slips into a slot in TP lever
Old Apr 20, 2014 | 01:24 AM
Black LS2's Avatar
Black LS2
Sounds like an aftermarket cruise control; the Audiovox CC has a large version of a dog tag chain on it at the TB. The Audiovox is a decent aftermarket unit; it will integrate with the stock turn signal cruise switch. I would bet that is not your problem.
When you say 'accelerate', are you under load (moving), or just increasing the engine RPM at a stand still?
Old Apr 20, 2014 | 02:46 AM
skysurfer2000
4th Gear
You guys are fantastic i finally found out that device is a cruise control and the cruise control is loose i guess when the old owner changed the battery it never put it back correctly its loose under the engine compartment under the hood tomorrow morning ill try to play around disconnet the device or something, the car accelerate fine when i accelerate manually from under the hood with my hand when i use the accelelarator the car doesnt go up with rpm only at high speed on the freeway otherwise the car stalls at low rpm it seems clogged not regular it seems that something choke the accelaration i really hope its the cruise control so i can disconnect it
To 1989 corvette accelaration
