brake pedal assembly removal
Old Apr 19, 2014 | 10:43 PM
383tpimachine's Avatar
383tpimachine
Default brake pedal assembly removal
Anyone done it?
Not sure how to get the old assembly (auto) out and new assembly (manual) in.
Any help would be appreciated.
Thanks.
Old Apr 19, 2014 | 11:37 PM
Fastime's Avatar
Fastime
The bracket assembly for the auto and manual is the same, just swap out the brake petal. Then you only need to add the manual assembly to the left of it.
Old Apr 20, 2014 | 07:05 AM
383tpimachine
If this is true I will have a much easier time than I assumed.
I will check more into the setup tomorrow. thank you.
So to revise how hard is it to add the clutch pedal/bracket?
Old Apr 20, 2014 | 11:52 AM
Fastime's Avatar
Fastime
Remove the steering column to make the job easier.
Old Apr 21, 2014 | 02:05 AM
Cruizin's Avatar
Cruizin
Also suggest you remove the dash pad. The pedals mount high up behind the dash so the extra light and access may make the job a bit easier.
To brake pedal assembly removal
