86 c4 vacume lines toast
Old Apr 20, 2014 | 11:44 AM
rochhound's Avatar
rochhound
Default 86 c4 vacume lines toast
im rebuilding my 86 350 but all my vacume line are toast!
broken every where,what to replace with,new plastic or go to rubber
i assume there are no ready made kits available any help would be appreciated.
thanks
Old Apr 20, 2014 | 12:31 PM
WW7's Avatar
WW7
As mine break, I just use rubber to replace them...If you want to use plastic you can get it at most auto part stores....WW
Old Apr 20, 2014 | 01:09 PM
WVZR-1's Avatar
WVZR-1
You should be able to nearly duplicate the original using nylon tubing and some nipples and couplings that are available. To keep it very clean you may need to be somewhat creative and snagging some salvage at an older salvage yard could be a big plus. Patience!
Nylon with nice nipples and connectors certainly offer up an appearance plus!
Old Apr 20, 2014 | 03:31 PM
hcbph's Avatar
hcbph
Default Hoses
I had a couple of bad hoses when I got mine. I bought about 5' of hose, replaced the bad ones and looked for others. Anything that looked bad was replaced then when that was done I used the rest to change out anything that looked 'old'. Seems to have taken care of a lot of issues.
Old Apr 21, 2014 | 04:36 AM
Cliff Harris's Avatar
Cliff Harris
There is one "harness" (as GM calls it) available (part number 14082463 -- pretty cheap and avoids the hassle of putting together a bunch of pieces):
You can buy the plastic vacuum tubing at any auto parts store. It's very sensitive to heat. I tried heating it with a heat gun to bend it and it melted. I found that I could run the tubing and the heat of the engine would "form" it after a while.
To 86 c4 vacume lines toast
