Tread direction on Tires!!!
Old Jul 19, 2002 | 10:00 AM
bwagner's Avatar
bwagner
Default Tread direction on Tires!!!
I went out and got tires from Pep Boy's. Didn't want to spend to much on what I usually get because of trading in the C4 in for a C5 at the end of the year. So I went cheap and got the Z-Rated tires from them. After putting them on and driving it down the road, the rear end of my car is every where. It feels like the tires are following every crack in the road. I got it home and looked at the tires. The left side tread is running forwarded and the right side tread is running backwards. Is this right? I went back to Pep Boy's and showed them and told them what was going on and they told me that they were not true directional tires...they tried giving me all these excuses that it shouldn't matter and that it's a harder tire than what I'm use to. It may be a harder tire but they should both be running in the same direction. Right???????
I guess if you go cheap you get cheap.....
:mad
Old Jul 19, 2002 | 11:30 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Tread direction on Tires!!! (bwagner)
Look for directional arrows on the sidewall. It could also be the alignment.
Old Jul 19, 2002 | 11:47 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Tread direction on Tires!!! (92Shawnster)
Did you get the ones with the whitewalls? ;) You get what you pay for. I certainly did. :yesnod: If you want a good bargain replacement, look at Kumho, Firestone SZEP and Bridgestone RE 730s. But I feel one of the most important parts of a car is the tire. It is the conduit by which the engine, brakes, and handling of the car is brought to bear. As such, it can be a weak link in all three areas. So while I might skimp on say shocks or brake pads, I wouldn't on tires. :yesnod:
Old Jul 19, 2002 | 01:27 PM
Admiral Fairway's Avatar
Admiral Fairway
They put the one tire on backward, you should make them change it, if it didn't matter the manufactor would not go to the trouble of putting a arrow on the sidewall.
Old Jul 19, 2002 | 02:23 PM
bwagner's Avatar
bwagner
Default Re: Tread direction on Tires!!! (cnl3rd)
The thing is that both tires show "Mount this side out" on the outside of each tire. So that's what they were telling me that they are not true directional tires.....
Old Jul 19, 2002 | 08:13 PM
HighHopes85's Avatar
HighHopes85
What brand are they? You make it sounds like it is actually a directional tread pattern. In that case... :eek:
Old Jul 19, 2002 | 08:20 PM
Ivory90's Avatar
Ivory90
Default Re: Tread direction on Tires!!! (92TripleBlack)
Right on 92TripleBlack...I have the Bridgestone RE 730's...this is a VERY GOOD TIRE for the money...I did my research through http://www.tirerack.com and I wasn't at all disappointed with my purchase...these are NOT cheap tires, they stick like glue and wear so far (4-5 months) is excellent.
Old Jul 20, 2002 | 12:28 AM
ZELLSLIFE's Avatar
ZELLSLIFE
If they both say Mount This Side Out and one has a backwards pattern sounds like they gave you two left shoes. I'd bet they are directionals hence the MOUNT THIS SIDE OUT statement. I had a tire salesman tell me 285 40 17's were truck tires too :lol: :lol: Tire Rack is the cureall great prices, shipping and service without the :bs . Good luck
Old Jul 20, 2002 | 01:04 AM
VetBoyZR1's Avatar
VetBoyZR1
Default Re: Tread direction on Tires!!! (ZELLSLIFE)
Tell us if it says ROTATION >>>>>> on the sidewall, that will prove it.
Old Jul 20, 2002 | 12:02 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Tread direction on Tires!!! (VetBoyZR1)
That's right, if you look at drag radials, they are not directional, but they do have an inner and an outer side.
Check your tire pressures, or have them rebalance them, looks like they are mounted properly.
Old Jul 21, 2002 | 09:47 PM
R23HTC's Avatar
R23HTC
Default Re: Tread direction on Tires!!! (Mr Mojo)
Mr Mojo is right. Just because it says mount this side out doesn't mean it's directional, it means it's asymmetrical. I know a Pirelli tire that's asymmetrical but not directional. Think of it this way; a directional tire has to be taken OFF the rim to be mounted to the other side of the car, otherwise it would be going the wrong way. An asymmetrical tire can be mounted on the other side because once it's mount facing out on the rim, the side of the car doesn't matter, it still FACES out.
Old Jul 21, 2002 | 11:07 PM
red-y's Avatar
red-y
You got to watch them "Pep Boys" - they will run you - :yesnod:
Old Jul 22, 2002 | 09:20 AM
bwagner's Avatar
bwagner
Default Re: Tread direction on Tires!!! (R94 LT 1)
If you go here http://www.pepboys.com/tires/peptire.../futuraultraz/ you will see the tires I got. They are asymmetrical.
So why is rear end all over the road then? You would think if it was the alignment it would have been like that before with the other tires I had on there. They were still good tires. The only reason I got them replaced was due to a nail in the side wall of one. So I replaced them both. Plus I just got an alignment done about 7-8 months ago. Unless my alignment is off again already...
It sucks, I never thought I would get to a point of not wanting to drive my car. But it's that bad....
:mad
Old Jul 22, 2002 | 10:31 AM
92TripleBlack
http://www.carreview.com/PRD_31165_1577crx.aspx
Here's some reviews of them. They are made by Cooper for Pep Boys. They don't look real impressive. Even the Pep Boys site says they are about as good as regular Goodyears, which are worse than the Goodyear GSCs the car came with, which are the worst tires I have ever ridden on. A set of Bridgestone KDs or Pilot sports will put you well into C5 handling territory, not C3. This is probably why you are so frustrated with your car.
Old Jul 22, 2002 | 10:36 AM
SlowJoe's Avatar
SlowJoe
Yikes, if they are good as Goodyear, they are crap. The single best thing I ever did for my car is replace the original tires. Goodyears handle like crap.
Old Jul 22, 2002 | 10:48 AM
92TripleBlack
Default Re: Tread direction on Tires!!! (SlowJoe)
As good as good year eagles, which are crap next to the stock GSC which are crap next to a good tire which are crap next to a top end tire. Heck, the thing would probably handle better with the tires from my Grand cherokee bolted on.
Old Jul 22, 2002 | 11:09 AM
R23HTC's Avatar
R23HTC
I would also check to make sure ALL 4 TIRES they put on are the SAME SIZE! My brother got 4 tires from NTB once and they put 3 on that were the right size and one on that was just a little BIGGER :eek: :eek: :eek: He was having similar handling problems. :mad :mad :mad
To Tread direction on Tires!!!
Old Jul 22, 2002 | 03:28 PM
Jim-K's Avatar
Jim-K
maybe they mounted the wheels wrong... i.e 400 psi on the impact gun, full tourque on the first bolt. Verify your rims arent bent.
I hope I'm wrong about this
I always make them mount my wheels by hand, and also bring them a tourque wrench all set up to the 100 ft-lbs..
Jim-K
Old Jul 22, 2002 | 04:57 PM
bwagner's Avatar
bwagner
Default Re: Tread direction on Tires!!! (Jim-K)
Jim-K
:lol: :lol: That's funny, I'm the same way, therefore I just dropped off the two rims. So I'm the one that put them back on....
Old Jul 22, 2002 | 05:15 PM
Jim-K's Avatar
Jim-K
Well, when i first got my 86, it was real nervous on the road. Ruts on the highway could literally pull the wheel out of my hand, it was spookey.
My tires were seperating. It was quiet obvious by spinning the wheel and looking at it. It was all lumps and bumps. (front a bit easier to ck then the rear) I think this was the biggest problem.
Since then i've put new tires, (firehawk sz50's), new bearing hubs, poly suspension, ball joints, u-joints, and one inner tie rod end. Now its rock solid straight, and although hwy ruts can move the car around a bit, it does not want to make me change my diaper like before.
So if your tires are round, then i'd ck the tie rods, both front and rear, and the hubs. Something is causing the suspension to lose its geometry.
Firestone usually gives me a free inspection for this.
Good Luck
Jim-K
