1986 c4 Annoying squeal.
Old Apr 24, 2014 | 01:13 PM
MarcusWrenn's Avatar
MarcusWrenn
Cruising
Default 1986 c4 Annoying squeal.
Changed my smog pump (not the pulley) hoping that was my problem. The squealing stopped last night, but has started again this morning.
should i try changing the belt also?
Change the pulley?
Someone help before I go Deff!
thanks!
Old Apr 24, 2014 | 09:53 PM
Square's Avatar
Square
You have probably done this, but have you removed the belt and spun each pulley individually to find the source of the noise?
Change the pulley?
thanks!
Old Apr 26, 2014 | 02:22 PM
DanZ51's Avatar
DanZ51
Dayco (belts) has a bunch of videos regarding diagnosing belt noise.
Old Apr 27, 2014 | 06:27 AM
HlhnEast's Avatar
HlhnEast
Annoying squeal?
1) Open passenger door
2) Remove wife
3) Problem solved.
Or if your nice
1) Open Door
2) Install diamond on wifes finger
3) Problem solved.
Old Apr 27, 2014 | 07:30 AM
Cruizin's Avatar
Cruizin
Originally Posted by HlhnEast
Annoying squeal?
2) Remove wife
3) Problem solved.
Or if your nice
1) Open Door
3) Problem solved.
Very funny!!
Old Apr 27, 2014 | 07:48 PM
hcbph's Avatar
hcbph
Default Squeal
I had a squeal out of mine over winter storage when I would start it up for the monthly run. It was the alternator when it was cold out. Once it warmed up the squeal went away.
To 1986 c4 Annoying squeal.
