radiator sprung a leak
Old Apr 24, 2014 | 09:41 PM
bassackwards's Avatar
bassackwards
Default radiator sprung a leak
While cruising around town with the top down I got a whiff of antifreeze and noticed my low coolant light came on. I pulled into a gas station and steam poured out from under the hood. I raised the hood and coolant was spraying in a 1/8" stream coming from the side of the radiator tank where it meets the aluminum.
Is it toast and what brands should I avoid?
Old Apr 24, 2014 | 10:01 PM
DanielRicany's Avatar
DanielRicany
It probably leaked through the gasket between the core and the plastic tanks. I bought a American Eagle 2 row aluminum radiator with 1 inch tubing for $200. This company got very good reviews, they are part of Champion radiators. You'll need to do some modifications for the rubber grommets and the fan shroud to get it into place. Don't know if you're up to that but from what I see and hear its a pretty good radiator.
Old Apr 24, 2014 | 10:42 PM
charliet615's Avatar
charliet615
Lonnie, there is a place on Elm Hill Pike called Radiator Plus. I bought one for my 90 model a couple of years ago for 99.00. It worked fine for that car. 615-244-2200 Give them a call. Charlie
Old Apr 24, 2014 | 10:51 PM
scotth48's Avatar
scotth48
If your going to replace it, go with a DeWitt's single row. It is larger than the stock one and very high quality construction. It is well worth the additional cost over foreign made ones, see there sponsor link here on the forum under cooling.
Old Apr 25, 2014 | 01:43 AM
Cliff Harris's Avatar
Cliff Harris
You may not want to go this route, but the gaskets between the tanks and the tubes can be replaced. A radiator shop would be able to advise you on what's needed.
Old Apr 25, 2014 | 05:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When the same leak happened to my '88 IROC-Z I got a new one from the local AC Delco dealer for ~$100.
Old Apr 25, 2014 | 08:01 AM
93 ragtop's Avatar
93 ragtop
If your car is stock, and you don't plan on any really radical changes, I would just go with a stock replacement. The stock system cools well and for $100.00 or so, it cant be beat.
FWIW I went with one of the Champion aftermarket radiators, due to having to replace mine anyways, and the fact it is making close to twice the hp it came from the factory with. Otherwise I would have stayed stock and used the extra money somewhere else.
Old Apr 25, 2014 | 09:38 AM
bassackwards
I want to keep a stock fit, I'm not into fabricating and my engine is stock.
Cheapest one I've found locally is $128.
Should I change to a lower thermostat and what temp?
Old Apr 25, 2014 | 09:44 AM
GKK's Avatar
GKK
A Stock Radiator will be fine (mine lasted 130K) also, use the stock rated thermostat.
Old Apr 30, 2014 | 08:31 PM
bassackwards
So I got a replacement radiator and got it in today. The steam pipe nipple on the top rt appears to be too small. I cannot get it to seal and measured it with calipers. It is no doubt smaller than the previous radiator.
Old Apr 30, 2014 | 09:14 PM
C4in mesa's Avatar
C4in mesa
Too bad you don't live close to me. I would give you a stock radiator for $20.
Old May 9, 2014 | 06:37 PM
bassackwards
Got a replacement radiator installed and while running with just water for testing purposes the cruising temp appears to have dropped down to 192 from a rock solid 200 before the new radiator.
I also swapped all the hoses and added a new 180 thermostat only to see that my old one was stamped 180.
I'd still like the fans to come on sooner but I don't want to go through chip programming right now
Old May 9, 2014 | 07:39 PM
c4cruiser's Avatar
c4cruiser
Sounds like everything will be OK. Assuming the old radiator was OEM, the chances are that there was dirt and debris embedded between the fins and tubes. Less airflow means higher temps. Also, the tubes will get thin over the years due simply to coolant passing thru. Thinner tubes will not allow for good heat transfer.
I would also get a new pressure cap if the new radiator didn't come with one. Should be 15 psi.
With the indicated temp of 192 that you saw, there should not be any real need for having the fans to come on at a lower temp.
Old May 9, 2014 | 07:58 PM
bassackwards
The fans dont come on until 228 when sitting in traffic
Old May 10, 2014 | 03:32 PM
desertmike1's Avatar
desertmike1
This is normal! no worries..
Old May 10, 2014 | 04:04 PM
bassackwards
I know but I wouldn't mind seeing them come on around 200 or so.
To radiator sprung a leak
