I know everybody says corvettes run hot and whatnot.. but my car just idling on a 70* day w/ my hands by the brake booster is EXCRUCIATINGLY hot. I mean, holy damn... HOT.
Headers could be contributing to the heat. The C4s have a sealed engine compartment. There is simply no where for the air to go except for around the underside of the motor. The clamshell hood is sealed to the firewall and around the wheelwells. When I carbed my C4 years ago, I had a bad problem with fuel perculation. Even with ducts cut into the hood, the problem still did not resolve. That's one reason I went balk to fuel injection. And yes, I tried wrapping my headers.
Actually air is pulled in through the radiator, flows across/around the engine and out through the "gills" behind the front wheels.
Indeed a coating inside/out like Jet Hot will reduce exhaust heat flow into the engine compartment. I had coated FL headers on my prior IROC-Z and I could almost lay my hand comfortably on the headers..
The inside coating is particularly important as it tends to keep the heat in the exhaust gas, just where you want it.
Looking at the picture, the gills are near the bottom of the motor. The top of the motor is still sealed and as hot as Hades. I've fried more than a few knuckles rushing to change plugs when the motor is still hot with coated headers. Try spitting on your headers a minute or two after shutdown. Definitely hot enough to fry an egg. The coating does lower the underhood temperature a few degrees, but in my opinion not enough to make a difference. It's main benefit is to allow hot exhaust gasses to pass through the exhaust system keeping the velocity high. Wrapped headers will lower underhood heat much more than ceramic coated headers.
Read something bout pc fans used too blow out the gills. Also read some cut the seal by the back of the hood.
I cut out the rear of my hood open, sort of like the opening on a cowl induction hood. It helps a little. My hood is starting to look like Swiss cheese.
I can't find it right now, but I remember reading of a member removing the seal that runs along the top of the hood/top of firewall and he said it helped lower the temps under his hood. I haven't tried this yet, but I am also noticing my carb makin' coffee. May try it this spring. (after I get my ball joints, poly bushings, f & r wheel bearings, shifter, 383 swapped in...)
Yeah, I got tired of the fuel perculation wiping out my rings. Try using a die grinder or dremel and open up the vertical wall on the back of the hood. There is a front and back wall to gring through. That will help more than removing the seal. Actually, do both.
