ODB I code 15
Old Apr 25, 2014 | 07:44 PM
newbie2vette's Avatar
newbie2vette
Default ODB I code 15
Temps got down to in the 40's in my area yesterday, I went to start our 1992. It did not want to start, it took several try. When it finally started, the CEL came on; got the code it was 15. coolant sensor low temp.
Can I get some help pointing where this sensor is located? thank you.
Old Apr 25, 2014 | 09:50 PM
don hall's Avatar
don hall
[QUOTE=newbie2vette;1586750307,,,,,,
Can I get some help pointing where this sensor is located? .....[/QUOTE]
The digital temp sensor is located in the water pump (front of engine).
The analog temp sensor is located in passenger-side head....this
sensor just moves the analog needle.
If you remove the digital temp sensor, take care to not 'flood' the opti by packing rags around the area,.
