Wideband O2 Sensor to the ECM?
Old Apr 28, 2014 | 06:02 PM
DanielRicany's Avatar
DanielRicany
Default Wideband O2 Sensor to the ECM?
Hi guys, I have a modified 1985 Corvette with the 870 ECM. I was just thinking, and started wondering if it is possible to wire a Wideband O2 sensor to the ECM using the wires for the Narrowband O2 sensor?
Thanks!
Old Apr 28, 2014 | 06:13 PM
STL94LT1's Avatar
STL94LT1
I wish it was that easy.
Old Apr 28, 2014 | 07:18 PM
T. Wayne Nelson's Avatar
T. Wayne Nelson
I have a gen 7 and running a wide band. I would think you have to change the ECM..
Old Apr 28, 2014 | 07:22 PM
MrWillys's Avatar
MrWillys
Watch the narrow band in your logs and to the pe to .860.
Old Apr 28, 2014 | 08:48 PM
ultraviolet70's Avatar
ultraviolet70
Some of the wide bands (not the sensor itself but the module) have an output that can be directly connected to the stock ECM.
For instance I have a Zeitronix that has this feature and it works well. This made it nice that I only had to have the one O2 sensor this way.
To Wideband O2 Sensor to the ECM?
