A/C hoses
Do not forget to change all the O rings with the green ones for R134A, lubricate the o rings with PAG oil and do not over tighten.
Replace the accumulator, orifice tube and drain all the mineral oil from the compressor. Add the correct amount of PAG oil to the compressor as per your shop manual ,turning the compressor as you go do not overfill with oil.
Evacuate the system check for leaks and charge with R134A by weight, you want no more than 80% of the R12 by weight..
Again check for leaks, if you do not have an electronic leak detector use some dishwashing liquid and some water. A hand spray bottle will be the way to go, spray over all connections and look for bubbles.
All that's left is go for a drive and enjoy
Done properly you should have cool reliable air for many years.
Here is the quantity in oil and gas for 84-87 Corvettes.
6 oz PAG oil.
2.75lb R12 means 2.1 to max 2.2lb R134A.
Last edited by gerardvg; May 1, 2014 at 05:26 AM. Reason: Oil and refrigerant quantity added
