What does this mean?
Old May 1, 2014 | 12:08 PM
DanielRicany's Avatar
DanielRicany
Default What does this mean?
Hi guys, I have a 1985 Corvette and I was using a power probe to test one of my wires for the burn off module. Anyway, it would beep, stop, beep, stop, beep, stop, etc. etc., but really quickly.
I figured I may have a bad connection somewhere causing it to do that. So my next step was to go to the fuses. When I tested some of the fuses, a about 1/3 of them did the same thing.
I have it all on video.
Is that normal or does it mean there is a bad connection somewhere or something?
Thanks!
Old May 1, 2014 | 12:27 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Looks to me like you have 10.9 -11.1v at all of the fuses. As for the way the device is beeping, I'd suggest reading the directions that came with that particular device. It seems like there may be a poor connection in some...could be the fuse itself, or the probe on the fuse. Looking at the LCD, though, it looks normal to me, (If not slightly low voltage).
Old May 1, 2014 | 01:06 PM
DanielRicany
I looked through the little packet that it came with and I wasn't able to find anything. I'm going to try testing it with my multi meter and a test light and I'll let you know what happens. Thanks!
Old May 1, 2014 | 02:52 PM
DanielRicany
Okay, It Doesn't Do It With The Multimeter Or Test Light.
Old May 1, 2014 | 03:10 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
O.K. Looks like you have Batt voltage at your fuses then.
Old May 1, 2014 | 06:48 PM
hooked073's Avatar
hooked073
some of the meters are designed to beep if it is seeing less then I think 12.3 volts. google it see whaty you come up with
Old May 1, 2014 | 06:54 PM
WVZR-1's Avatar
WVZR-1
Complete manual is likely this:
http://www.powerprobe.com/images/man...P3_English.pdf
The FAQ's might help on the link also. I can't imagine attempting to use a tool without understanding it's operation.
I didn't waste my time on the video.
To What does this mean?
