Shift light
Old May 3, 2014 | 05:51 PM
Dyno Don L.'s Avatar
Dyno Don L.
Default Shift light
Does the '90-'91 C4 with AXCN have a shift light?
Old May 6, 2014 | 09:46 PM
Dyno Don L.
Really? no one knows if a 'vette has a shift light in '90-91 with a
6 spd.?
Old May 6, 2014 | 10:40 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
IIRC all C4 6 speeds were equipped with the skip shift feature, from most posts on the subject it has been eliminated.. The kit for this doesn't get rid of the light though..
Old May 6, 2014 | 10:45 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
6 spd.?
If you mean a light that tells you when to shift, then no.
Old May 7, 2014 | 10:24 AM
Hooked on Vettes's Avatar
Hooked on Vettes
6 spd.?
The ECM has the circuitry to drive the Up shift bulb in the dash cluster.
90 Service Manual says, in vehicles equipped with a Manual transmission,
a bulb lights when the car should be shifted to
the next higher gear for better fuel economy. Battery voltage
is applied to one side of the bulb. The other side
of the bulb is switched to ground by the ECM which
uses engine data such as rpm, vehicle speed and intake
vacuum to compute an efficient shift point.
The diagram even shows an overdrive bulb for automatic transmissions.
The 1990 owners manual only says this for a manual transmission.
For a L98 Vin 8 vehicle you have an up shift light on your instrument
panel. This light will remind you to up shift to Sixth gear during cruising.
If you have a ZR1, this light will also indicate the up shift point for optimum acceleration during wide-open throttle maneuvers.
Whether this up shift bulb function was actually implemented in the eprom firmware code
I've posted a diagram showing the up shift bulb position in the dash cluster if you want to verify it's there and not burnt out.
Old May 7, 2014 | 11:28 AM
Dyno Don L.
Cool, that is just what I needed.
There must be something in my program then that keeps it from working.
I am using the AXCN broadcast code bin file.
Thank you.
Old May 7, 2014 | 06:01 PM
WVZR-1's Avatar
WVZR-1
For the LT5/ZR-1 that light/feature was disabled on the first PROM revision. It can be added back but regarding the L98 I've actually no idea if it did work and was removed like the LT5 revisions or not. Maybe? What revision is the AXCN?
To Shift light
