door light bulb replacement
Old May 4, 2014 | 07:41 PM
cormorant71's Avatar
cormorant71
Default door light bulb replacement
ok, last thread, i promise
i should be done with the restoration in a coupld of weeks and i will post some before and after pics.
thanks again to everyone that has helped. here is my little bit to help
changing the light bulb on the door is not as bad as it seems. remove or at least loosen the black trim plate. then you can access the light cover. on the side that says "push" there is a notch to insert a flathead screwdriver and pry it towards the back of the car. it will swing open and then you can replace the bulb. really not that bad.
here are a couple of pictures that i hope help
chris
