Not getting fuel!?
Old May 4, 2014 | 11:32 PM
fjcaserta's Avatar
fjcaserta
5th Gear
Default Not getting fuel!?
I am going to start from the back and work my way forward.
The car sat for 4 years so I knew i was going to have to go through fuel system. I took the tank out and cleaned it. I change the sending unit and pump, I change the fuel lines from the tank to the filter , changed the filter and I blew air from the filter to the fuel rails. I did not touch the fuel rail or fuel regulator. I change all the injectors, I check all the wiring make sure there was no shorts. I have no clue what else I am missing but I am not getting fuel. I will keeping spraying starter fluid in and it will run forever but I need the fuel. Please help. Should I take the fuel rails off and clean them, or open up the fuel regulator? Or is there something else?
Old May 5, 2014 | 01:29 AM
Cliff Harris's Avatar
Cliff Harris
Check your fuel pump relay and associated connectors and wiring. It is operated by the ECM. It should turn on for 2 seconds when you turn on the ignition. It should also turn on when the engine is rotating, either cranking or running.
Old May 5, 2014 | 02:00 AM
fjcaserta's Avatar
fjcaserta
5th Gear
I know the electric works I had the local mechanic put his computer on it and I disconnect the fuel to the fuel rail and I am getting gas until that point, so I know the pump and everything works
Old May 5, 2014 | 02:29 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
It always helps if you provide the year of your vette.. Did your mechanic check for fuel pressure, and spark, put a noid light on the injectors to check for its pulse??
To Not getting fuel!?
