Differential cover repair
Old Jul 20, 2002 | 09:44 AM
Putter's Avatar
Putter
Default Differential cover repair
My 90 convertible differential cover has a slight leak. Has anyone repaired a leak? I know that the spring has to be removed and that the suspension arms must be disconnected. I am mechanically inclined, just wanted to know if anyone has "discovered" any hidden tricks or pitfalls that I might need to know about before taking on this task?
Old Jul 20, 2002 | 03:08 PM
silver & red CE's Avatar
silver & red CE
Default Re: Differential cover repair (Putter)
I read a post last week where someone found the source of the leak on the diff cover and squirted a little RTV in the crack, covered it with tape while it dried. Sealed it up. Might be worth a try. Otherwise, I'd change the gear while the diff was out ;) I used Permetex "The Right Stuff" to seal my case. Worked the first time and I'd never done it before.
Eric
