Is it supposed to glow?
Old May 5, 2014 | 05:57 PM
DanielRicany's Avatar
DanielRicany
Default Is it supposed to glow?
Hey guys. I have a 1985 Corvette and I just replaced the burn off module today because it tested bad. I read somewhere that when you turn the car off after being in closed loop you should see the wire inside the MAF sensor glow orange. Is this true? Mine does not do this and the new module tested good. Thanks!
Old May 6, 2014 | 03:29 AM
Cliff Harris's Avatar
Cliff Harris
I have done this test and it did glow orange for about a second right after I turned off the ignition. It's not blindingly bright or anything like that. Just a slight red glow, so you need to be in a relatively dark place. I did this on a MAF that had the screens removed, so it might be harder to see if you have screens in your MAF.
