Still having MAF sensor burn off problems...
Old May 7, 2014 | 10:02 PM
cumbercr's Avatar
cumbercr
Originally Posted by DanielRicany
The MAF Sensing Wire Doesn't Glow During Burn Off.
Did you do the C-13 functional check? If so, where did it lead?
Old May 8, 2014 | 08:59 AM
DanielRicany's Avatar
DanielRicany
It Lead Me To No Trouble Found, Review symptoms Section.
But Then All Data Says If The Wire Isn't Glowing, Refer To The chart. So Basically I'm Stuck In A Circle...
Old May 8, 2014 | 04:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the MAF & BO module behave properly on the bench it soulds like the ECM is not calling for burn off??
Have you tried running the engine till it goes closed loop before shut down to view the wire?
Old May 8, 2014 | 04:22 PM
DanielRicany
Yes
Old May 8, 2014 | 07:52 PM
cumbercr's Avatar
cumbercr
I think you're chasing a non-problem. The C-13 chart checks for a signal from the ECM as well as primary power. It sends you to Section B to look at other causes for whatever you are trying to troubleshoot.
Old May 8, 2014 | 08:50 PM
856SPEED's Avatar
856SPEED
What drive ability issues are you having exactly?
Old May 8, 2014 | 08:55 PM
DanielRicany
Idle surging, Occasional Backfire During Revs, And Sometimes A Backfire When I Get On It On The Highway. Lean Spikes On My Afr Gauge.
My Car Has A Lot Of Modifications Though. And I Do Have A Tune.
Old May 8, 2014 | 09:28 PM
hooked073's Avatar
hooked073
Burn it off manualy run it for a couple hundred miles and see if it solves all your problems if it does not you know that is not the issuse
Old May 9, 2014 | 03:29 AM
Cliff Harris's Avatar
Cliff Harris
My '86 ECM has these parameters for MAF burnoff failure:
LC223: FCB 95 ; Fail burnoff test if ADC > 1.90 VDC
LC224: FCB 20 ; Fail burnoff test if ADC < 400 mVDC
Yours should be similar, if not the same. These are the voltages on the MAF output, not the voltages on the burnoff wire.
The schematic for the burnoff module clearly shows "BURN-OFF CONTROL" and it appears to apply 12 volts to the MAF sensor wire through a relay. The burnoff relay might not be working or have dirty contacts.
Have you looked at the PC board inside the MAF burnoff module? There might be burned components or bad solder connections. This post has a bunch of pictures of what to expect:
http://forums.corvetteforum.com/1571196606-post1.html
Old May 9, 2014 | 10:58 AM
DanielRicany
This is what the NEW module looks like. Looks the same as the old one which was diagnosed as faulty. Looks like some corrosion around the relay contacts.
Old May 9, 2014 | 08:38 PM
DanielRicany
I guess that means it's bad right? I would test the resistance on it but some wiring diagrams say Solid State do not measure resistance, for like the ECM and some other modules. It doesn't say it for the Burn Off module but it does say Solid State on the diagram.
Old May 10, 2014 | 02:31 AM
Cliff Harris
That looks like solder flux to me (electronic engineer for a LONG time). It appears the relay was replaced but the flux was not cleaned off. You can clean it with alcohol.
Old May 10, 2014 | 07:16 AM
  #33
Klyde's Avatar
Klyde
Cliff:
I'm also an I&E Tech and thought the same thing when I saw the pic. It looks like someone replaced the relay and didn't clean off the flux. Should clean off easily.
DanielRicany:
If this board is mounted in a position where you can see it working with the cover off you could watch the relay to make sure it pulls in. Also you might check the main contact to make sure its clean since its exposed.
Old May 10, 2014 | 08:08 AM
  #34
DanielRicany
What About The Black Tint Around The little Ball? And If It's Flux What Are The Chances That Both Of My Modules Had This Stuff At The same Exact Points?
Thanks!
  #35
DanielRicany
The New Module Is Used By The Way.
Old May 10, 2014 | 12:34 PM
  #36
powerpigz-51's Avatar
powerpigz-51
You can measure solid state stuff if you have the right meter with a 10 megohm internal resistance. My cheap Walmart DVM has 10 meg. The "corrosion" you see is flux that has been getting hot at those solder joints. That is why both have the same thing, since it is used. I liked Hooked's idea.....you manually burned off the wire already, does it run any different?
