I'm porting out my intake so I need to replace the gaskets. What kind should I get and what part numbers? Where should I buy them? Should I replace the runner gaskets too?
Go to Auto Zone and get a Fel Pro intake manifold gasket set for your Vette. FelPro P/N MS93318 fits Chevrolet 350 V8s 1986-1993.
The set comes a small amount of black RTV to seal the two ends but get a large tube so you can lay down a healthy bead on each end of the block and have enough to apply a thin bead around each water jacket opening in the gasket set.
This set comes with TB to plenum, intake to runner, runner to plenum and other gaskets. Cost was about $35.
Thanks...do they have it in stock, or does it need to be ordered?
