Emission test: I give up!
Meanwhile the CO and CO2 values are OK, the called "lambda factor" is too high (1.2). Until I know, the lambda factor is the proportion of the fuel/air mixture. Values over 1 mean that the mixture is poor (too much air). So my Vette has too much air on the mixture, it seems.
Now, let me tell you that I have replaced the spark plugs and its cables, air and fuel filter, injectors, EGR valve, catalityc converter, mufflers, rear y-pipe (front seems ok)... Also, it is supposed that the O2 sensor was replaced also, but this is the only part that I never bought and was teorically replaced in the workshop, so I am not sure. These parts have been replaced during the last 5 years, but the car has had very little use, and I repeat that the high lambda factor returns every year, always with the same value of 1.2 since the first time...
Now I intend to order a new O2 sensor just in case, and also the EGR solenoid valve and tha cable that connects it. Will this change anything at last?????
Honestly, I do not know what more can I replace or do. Maybe the hoses, but they seem ok.
If you have any idea or know how can I reduce the lambda factor, any help will be very much appreciated. I am tired of always beg the inspector to let the car pass the test, year after year :-(
Indeed the above requested info would be very helpful in diagnosing the emissions issue.
If CO & CO2 are ok I can't see how they determine "too much air"???
In any case a scan of the ECM would likely shed much light upon the issue.
In any case, I will try to read pressures and voltages and let you know. Thanks!
Pull the O2 sensor and place a pressure gauge in the bung. Many vacuum gauges are also pressure gauges. With the engine running, measure the amount of back pressure. Mine read very close to zero. The EGR on the 95 needed some back pressure to operate correctly. What was happening is that it would just start to open, but the lack of back pressure would immediately close the valve. So the EGR was not doing what is was supposed to by opening and moving exhaust gasses into the cylinder to cool the cylinder and stop the creation of NOX.
I ended up having to put in restrictions in the exhaust pipe. I necked the pipe down from 2-3/4" right before the muffler to 1-1/4". That resulted in 1 pound of back pressure and the EGR worked and brought the NOX down.
