Broken wire ? What is it ?
May 9, 2014 | 03:13 PM
While working in my engine bay, i noticed this broken wire.
It is now repaired but Im hoping someone can help identify it.
Gray wire going from the injector harness to a connector under the plenum on the drivers side.
No check engine light, no codes.
May 9, 2014 | 03:32 PM
86-91 egr control valve relai solenoid
http://www.ebay.com/itm/1986-1991-Corvette-EGR-Control-Valve-Relay-Solenoid-/371048949531?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item56643da71b&vxp=mtr
May 9, 2014 | 04:01 PM
Thanks Bud...
I wonder if the occasional sputter might go away with the repaired wire?
May 9, 2014 | 04:35 PM
Quote:
Originally Posted by
aussie_g
Thanks Bud...
Yes. It Will. If The Egr Valve Is Not Opening During A Commanded Egr Cycle, The Fuel Mixture Will Go Lean And Can Cause A Lean Misfire Or Sputtering.
May 9, 2014 | 04:40 PM
Cruise-In II Veteran
The ECM will only call for EGR after some steady speed with coolant temp >175 deg F.
May 9, 2014 | 09:05 PM
I have noticed since I have had the car, after about 15 or so minutes of driving, it seems to get a slight stutter/hesitation.
I often noticed it at highway speed, with real light throttle
