HELP!!! TPIS header install question
Old Jul 20, 2002 | 08:11 PM
mn_vette's Avatar
mn_vette
Default HELP!!! TPIS header install question
Ok, the TPIS headers go in from the bottom, I'm trying to put on the one of the passanger side, how do I get it around the dipstick??? Can I take the dipstick off somehow or what. I know somebody out there has got the answer. Thanks
Old Jul 21, 2002 | 05:45 PM
corvette1990's Avatar
corvette1990
Default Re: HELP!!! TPIS header install question (mn_vette)
The dipstick does pull out, but first you need to unbolt one bolt that holds it in place. then pull it out. Make sure all the header bolt holes are large enough for the bolts to fit through. Mine had to be drilled out due to the coating made the holes smaller. Also check that the bolts with nut flanges will go through the holes at a 90 degree angle, and not cocked. I had to increase the dimples on several of the tubes to get the bolts to line up straight. You dont want to cross thread into alum heads. Look the headers over very carefully for the dimples from the factory. Then take a large socket (3/4) and bang it on its side on the dimple for more clearance. Keep all wires ty wraped or DEI asbestos wrapped, away from headers. I tried real hard and still melted one plug wire and one starter wire. Things/wires move once car is in motion.
Old Jul 21, 2002 | 06:46 PM
mn_vette's Avatar
mn_vette
Default Re: HELP!!! TPIS header install question (corvette1990)
ok where is this bolt that holds the dipstick holder in place? There's the one on the header wich is off, it there another. I looked around and couldn't see on at all. Don't forget we're talking about an lt1 now.
Old Jul 21, 2002 | 07:24 PM
93Blackrose's Avatar
93Blackrose
You will have to pull the dipstick. The only thing holding the dip stick tube in is the bracket that bolts to the exhaust manifold. Since you already have this unbolted you may have to tap the tube out by tapping on the bracket or on the bulb part of the dip stick tube were it goes into the engine block with a screw driver.
Old Jul 21, 2002 | 07:53 PM
black85's Avatar
black85
Default Re: HELP!!! TPIS header install question (93Blackrose)
I destroyed mine getting in out, but new tubes aren't too expensive.
Old Jul 21, 2002 | 08:30 PM
James94LT1's Avatar
James94LT1
Default Re: HELP!!! TPIS header install question (black85)
Just twist and yank up wiggle back and forth it'll come out. Don't have your face over it though wouldn't want to shove it in your eye or up your nose! :eek:
Its not bad. :D
Old Jul 21, 2002 | 09:22 PM
mn_vette's Avatar
mn_vette
Default Re: HELP!!! TPIS header install question (James94LT1)
Thanks guys!!! I got it. I've said it before and I'll say it again...
"When logic and reasoning fail, brute force will prevail"
Old Jul 21, 2002 | 11:33 PM
chucks88's Avatar
chucks88
Any in-progress pics that you can send along would be appreciated. I plan on putting TPIS headers on my car this year.
Chuck
Old Jul 22, 2002 | 12:13 AM
ZBRA's Avatar
ZBRA
Default Re: HELP!!! TPIS header install question (chucks88)
I have to clamp some vice grips on my dipstick and hammer away on them to get it out.
Old Jul 22, 2002 | 01:33 AM
mn_vette's Avatar
mn_vette
Chuck,
Sorry, I can't post anything I've got nowhere on the internet to store them. The biggest hint I could give right now is be prepared to jack the car WAY up. 25" of clearance is a long way. I had to go to Home Depot and buy some cement landscaping blocks and I've got two of those stacked up and then the jackstands on top of those. My biggest problem was unbolting the dual Cats on the LT1 which you shouldn't have on your 88. But I've heard the L98 heads create a need to fix some stuff. Good luck.
Old Jul 22, 2002 | 09:05 AM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
I might be coming to you for some advice also. I plan on getting TPIS long tubes in about a month. After my gears are done.
Old Jul 22, 2002 | 05:16 PM
mn_vette's Avatar
mn_vette
Default Re: HELP!!! TPIS header install question (UB2 SLOW)
advice #2 Figure out if you want to keep your EGR system before you start messing around with stuff. TPIS says that you need a different EGR tube but I don't see how. But I'm just going to get rid of mine all togther. You can plug the holes with GM part # 00445096. I looked all around town and this is the only thing with the right threading.
[Modified by mn_vette, 12:39 AM 7/23/2002]
[Modified by mn_vette, 3:09 AM 7/23/2002]
Old Jul 22, 2002 | 09:34 PM
James94LT1's Avatar
James94LT1
Is that part # for the holes in the header? I'm going to be removing my
egr with the new LT4 intake.
Old Jul 22, 2002 | 11:08 PM
mn_vette's Avatar
mn_vette
Yes, the hole on top of each of the headers for the EGR system to plug into. That part number is basically a bolt that will screw in there instead blocking up the hole. It's pretty :cool: that GM made a part to fit that :yesnod:
Old Jul 23, 2002 | 01:09 AM
ZBRA's Avatar
ZBRA
22mm oil drain plug guys. I plugged mine before shipping them to Jet Hot, that way the plug was coated/sealed at the same time.
Old Jul 25, 2002 | 09:04 PM
mn_vette's Avatar
mn_vette
A word of warning!!! I had to modify your cat back to get them to fit. The drivers side comes up and overlaps with the header about 4 inches. I did go to a muffler shop and had them make me two custom pieces to go in there after I cut back the drivers side and it cost me $20 for those.
Old Jul 25, 2002 | 10:11 PM
joe-red78's Avatar
joe-red78
mn_vette, how much did the headers cost ya? And what would you rate the installation difficulty as? I dont know if I should try to install myself or have someone do it for me?
Thanks,
Joe
Old Jul 26, 2002 | 09:19 AM
mn_vette's Avatar
mn_vette
Default Re: HELP!!! TPIS header install question (joe-red78)
Headers: $700
EGR block off plates: $24
Custom exhaust peices: $20
Cinder blocks(solid) for under jackstands: $15
Dremel cutting blades: $12
EGR block off bolts: $6
The chance to hear your car run with open headers: priceless :D
The install wasn't too bad. unbolt the headers, unbolting the cats was a pain, but I had to cut off support brackets to get the longtubes in there so I felt kind of dumb unbolting them, just cut off the brackets. Then drop the exhaust and repeat the process, nothing too dificult that you can't do without a ratchet and a dremel.
To HELP!!! TPIS header install question
