Is this the CAGS connector plug?
Old May 11, 2014 | 03:55 PM
DGXR's Avatar
DGXR
Default Is this the CAGS connector plug?
Changing the ZF6 oil on this car for the first time, noticed this plug disconnected:
Is this the CAGS "skip shift" connector, the same plug in question in this thread?
http://forums.corvetteforum.com/c4-t...cs-inside.html
The one in the thread above looks slightly different than mine and I want to be sure it's OK to leave unplugged. I like being able to select whatever gear I want. Thank you in advance for quick replies!
Old May 11, 2014 | 03:58 PM
tunedport85inject's Avatar
tunedport85inject
Yes is the skip shift solenoid connector
Old May 11, 2014 | 04:12 PM
DGXR's Avatar
DGXR
Good, thank you.
So if the skip shift system can be defeated simply by disconnecting this plug, why are people buying these (link)?
http://www.ebay.com/itm/like/130324375281?lpid=82
Old May 11, 2014 | 04:18 PM
tunedport85inject
cuz they like waste money on stupid gadget...its just a"plug" on the connector for 18 bucks...
Old May 11, 2014 | 05:00 PM
TA's Avatar
TA
I think 89-95 you can unplug it without issues, but 96 cars will set a code unless you get one of these plugs (or tune to eliminate the code).
Old May 11, 2014 | 08:03 PM
DGXR's Avatar
DGXR
One more question: Should I wrap the exposed contacts with tape, or maybe coat them with dielectric grease and wrap a baggie around each of them then secure with a wire tie, to preserve them? I don't plan to keep the car forever and perhaps the next owner will want the skip shift to be active.
Old May 11, 2014 | 08:36 PM
TA's Avatar
TA
Tape them up and you'll be fine.
Old May 11, 2014 | 08:54 PM
Trmccarty's Avatar
Trmccarty
Yes it is.
To Is this the CAGS connector plug?
