Code 36
Old May 11, 2014 | 08:10 PM
92C4M6's Avatar
92C4M6
Default Code 36
So i finally installed my new bosch III injectors today and immediately my old hesitation under light acceleration was cleared up. I was so happy been chasing this issue for a few weeks. Went down the rode driving normal until up to temp and gave it a romp, pulled strong but about 5500 rpms it stopped pulling and backfired and immediately through a CEL. So pulled over and checked the code got code 36. Weird thing is car still runs fine, has no noticeable power loss and revs freely to 6k. Only think that has changed is it is now hard to start(spins about 4-5 times before cranking) whereas before it was instant. Unplugged battery to clear code and still remains as does the cranking problem...ANY IDEAS? BTW Opti is a Delphi Unit installed in 2012
Old May 11, 2014 | 08:13 PM
bassackwards's Avatar
bassackwards
Either your opti or the associated wiring is the most likely culprit
Old May 11, 2014 | 08:37 PM
92C4M6's Avatar
92C4M6
Is there anychance its a wire or plug or something to or from the opti, like i said its a relatively new opti, and the car still runs great just hard to start all of a sudden and i cant get the CEL to go away. Only other time I ever had a bad opti was my 95 T/a and it ran like ISH and didnt throw a code?
Old May 11, 2014 | 08:39 PM
don hall's Avatar
don hall
Old May 11, 2014 | 08:52 PM
92C4M6's Avatar
92C4M6
Can you point out "the associated wiring" and any way to diagnose this problem without changing the opti?
Old May 11, 2014 | 09:00 PM
bassackwards
here is a 4 wire (maybe 5 on a 92) pigtail harness coming from the opti and running up the pass side of the intake to a plug right on top of the pass side near the fuel rail. This is how the opti communicates with the ECM. You could try checking your signals at the plug with straight pins pushed into the backside of the plug.
It is possible that the plug got disturbed or a wire got broken while changing the injectors. It is worth checking as they are in close proximity.
Old May 11, 2014 | 09:06 PM
WVZR-1's Avatar
WVZR-1
Do you have the FSM? Just do the diagnostics for the code from the start. The connector at the opti could be culprit or the other end of the harness but to avoid chasing "WAG" just do the diagnostics from scratch. Joe, Jim, Bob. Phil and his cousin will be of little use.
Old May 11, 2014 | 09:14 PM
92C4M6's Avatar
92C4M6
Zr1, abbreviations? Spell it out plz I'm assuming FSM=factory service manual?
Old May 11, 2014 | 09:18 PM
WVZR-1's Avatar
WVZR-1
Factory Service Manual - Wild A$$ Guess
Old May 11, 2014 | 09:25 PM
bassackwards
I may be a Wild A$$ but I'm not guessing
I have intimate knowledge of how optisparks work and in fact I seek out cars with opti problems and buy them. Thanks to my dealings with a certain vendor I have learned everything I can about how optisparks work.
His problem is between the ECM and the optical sensor but I'd start at the connector between the fuel injectors since they've been messing around right there.
Old May 11, 2014 | 09:33 PM
92C4M6's Avatar
92C4M6
Its dark and I cant mess with it any tonight, any pics of this connector near the injectors by chance?
Old May 12, 2014 | 10:14 AM
WVZR-1's Avatar
WVZR-1
Just follow the harness from the opti - you shouldn't need a snapshot. Do you have a FSM and a DMM (Digital Multi Meter) or DVM (Digital Volt Meter)?
Old May 12, 2014 | 01:43 PM
92C4M6's Avatar
92C4M6
I have access to the Voltmeter but I looked and I do not have the FSM
Old May 12, 2014 | 05:24 PM
92C4M6's Avatar
92C4M6
Additionally, can someone explain why the car still runs Great in all conditions? Wouldnt it run poor with a bad opti? Like i said the only issue is a SLIGHTLY more difficult start up? Is it maybe just the CEL doesnt wanna reset with a DCed battery?
Old May 14, 2014 | 07:00 PM
92C4M6's Avatar
92C4M6
The purple and white wire here between the injectors with ignition on registered 4.7 volts. Is there anywhere else I should check it?
Old May 14, 2014 | 07:38 PM
don hall's Avatar
don hall
........"Wouldnt it run poor with a bad opti?" ....
not necessarily.
...."Like i said the only issue is a SLIGHTLY more difficult start up" .....
typical with a code 36.
Just replaced my opti based on the same symptoms. Fixed!
Old May 14, 2014 | 09:04 PM
bassackwards
First off check the backside of each wire going into that connector from both sides. Tug on them a little and make sure they are seated. I stuck straight pins into the backside and checked voltage while the engine was running to find a heat related opti failure.
Old May 18, 2014 | 08:07 PM
92C4M6's Avatar
92C4M6
http://i723.photobucket.com/albums/ww231/epimax2008/c362.gif what is it referencing as terminal A and B?
Old May 19, 2014 | 09:30 AM
bassackwards
Starting in 93 they used a flat 4 wire plug and each terminal is marked. I converted my 92 to a 4 wire connector when I bought the junk Petris opti. Give me a little time today and I'll look through my old pics.
This connector has ABCD marks on the terminals. I believe A is the red wire with the probe in it and B is the purple/white wire
To Code 36
