86 rough idle and stalling when hot
Old May 12, 2014 | 03:07 AM
tintmandevin's Avatar
tintmandevin
Default 86 rough idle and stalling when hot
Late model 86 has rough idle after hot start. Runs fine from cold start. After car is warm and restarted it starts terrible idle from 1300 rpms down to 500 then back up. Sometimes stalls out. Only when hot. Car has new tps, iac, ecm. I bought iac from autozone for $35. Any chance I bought defective part?
Old May 12, 2014 | 03:58 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Are there any stored codes?
How is manifold vacuum before & after the rough idle?
Old May 12, 2014 | 06:46 AM
gerardvg's Avatar
gerardvg
Sounds like the EGR valve stuck and not closing fully, remove the vacuum hose at the EGR solenoid. Then check the EGR valve opens and closes fully.
Old May 13, 2014 | 04:15 AM
tintmandevin
Thanks gerardvg. I will check egr later today. Seems like there are several posts very similar to mine. Ill post results when I check. Car is running all emission systems. Probably lady owned because it is completely stock. Been working through minor problems for a year now but this idle problem is annoying.
To 86 rough idle and stalling when hot
