89 headlights open 1/2 way
Old May 13, 2014 | 11:11 PM
IMDMAN's Avatar
IMDMAN
3rd Gear
Default 89 headlights open 1/2 way
ive been searching thread on a fix for this and found a few helpful bits but where do I find the parts to fix this problem? I am only assuming its a bad gear but parts guy tell me there is no parts available for it anymore. where you guys finding these parts to fix this problem? thanks Les
Old May 13, 2014 | 11:45 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
This is one I found with a quick search..
http://www.mamotorworks.com/corvette...s-motors-gears
You might get away with just replacing the bushings..
This is a video of the procedure to repair the motor..
Old May 14, 2014 | 01:33 AM
hooked073's Avatar
hooked073
Google corvette parts and several places will show up. also look at the side of the page and you will see quite a few corvette vendors there also. There are little if not nothing you cannot find for the C4 reman,new or used you will be surprised. also remember just because it has corvette on it does not mean you cannot get what you want at you local parts store
Old May 15, 2014 | 12:09 AM
IMDMAN's Avatar
IMDMAN
3rd Gear
Default thanks
I found some parts on amazon to fix up the headlight. thanks for the video. should be simple job.
quick ?? what year did LS engine come out thnanks
Old May 15, 2014 | 01:14 AM
ccrazor's Avatar
ccrazor
IIRC the first LS series came out in 97..
To 89 headlights open 1/2 way
