Spark Plug Wire routing.....
Thanks for any tips.
Now what i disagree with you is the wires coming off the dist. I have a 90 FSM, and it clearly states wires #2 and 3 must be routed in front of the dist. and i dont think #1 should be in the 5-wire holder. I think it should be #2. Maybe your #1 wire is too long, so you routed it that way? I have my dist back in, and the wires connected. i just need to get the holders in correct position, and get #3 in the 5-wire holder. With it closer to the dist, i think i can make it work. I dont know the brand of my aftermarket wires. But they say "wired for life" on them, and they are 8mm blue wires.
I do have some C4 books, and they show pics of L98 motors various years, and the 5 wires in the holder. The detail is not as good as your pictures. I see you have the yellow Bosch injectors....last year i put in the blue Bosch IIIs.....i like them!
Actually now that i look at your first picture of which you say is factory, i think that cannot be. The factory dist has a plastic "ring" that holds the tops of terminal boots down. all 8 wires will come up off the dist in the ring, and it is supposed to be numbered. i dont see your ring, and the wire boots do not have a lip to catch the ring. Not trying to cause trouble here....
here's a pic of a 1990 vintage NOS L98 engine - note the routing at the rear of the distributor
as far as the ring on the distributor holding the wires, I've had three L98 C4's, and none of them had any ring holding wires. the wires in my first pic are the originals (note the number 8 on the one wire by the distributor. only original factory wires were number for the cylinders, and factory wires do not have a lip on the distributor boot. there is no ring, because there's not supposed to be one. see pic -
in one of my virtual photo albums, I have pics of my first 90 with the original wires, and their routing. both my 90 were original, and both routed and configured the same way. if I can dig them up, i'll post.
I stand by all my statements!
bought a roll 1" X 15' on fleabay. it's been on several months, about 1000 miles. doesn't seem to be any issues.
But actually i just switched wires 1 and 3, cuz 1 was so long and i wanted to run it like the FSM. 3 will have to go around one way or another. I will work on it today, and take a picture of what i come up with.
Love the pic of the vintage NOS engine.....shows the wires on drivers side good. I have the one corner bracket/wire holder, but do not have the one further in. I am thinking wire 1 goes the other way, cuz the boot is just too close to the plenum? I might have re-do several wires! These coil in cap dist's are HUGE!
Mine is routed the same way it came from the factory and #1 is in that 5-wire holder. Here's my setup (I don't have a picture of the 5-wire holder)
I have always bought AC Delco spark plug wires (several sets over the years) and NONE of them came with the boots that fit that ring. I just found it and threw it away about a month ago... For reference purposes, this is what it looks like:
I know that 1985 and 1990 models do not have that ring.
here's a pic of a 26K mile 85. it looks to be original, with the original sparkplug wires (note the "1" on the #1 wire near the front VC fastener). if you look closely, I doesn't appear to have any distributor cap ring. again, TBSS/85vette, can you post some pics - really curious here...
