I have to replace my runner and plenum bolts but can't find any replacements. My stock bolts say 10.9 on the head but I can't find any replacements and especially in stainless or chrome. I painted my runners and plenum black and I'd like some contrast if I can find nice replacements. Any help?
I believe 10.9 might be overkill but I would think some 12 point flange head in 8.8 might do well. Never tried but I've used a good bit of 12 point and I prefer it to most. You can do them in stainless also and I'm sure chrome.
Button head also shouldn't be a problem in chrome and metric. You can do all the way to 12.9 if you actually wanted.
These bolts are going into aluminum with a low torque value. grade 5 is more than enough. More important is to be sure that you coat the bolt threads with anti-seize!!!
I found a place that sells polished stainless steel Torx bolts, but you have to buy at least 100 pieces of each size, so that wasn't feasible.
There are stainless Allen head bolt kits available for Corvettes.
The local screw and bolt store has a nice selection of Allen head bolts. It's not a Fastenal store, but the local equivalent, McFadden-Dale Industrial Hardware. McFadden and Dale are the street names of the original location but they have several branches now.
ARP sells, or least they did a couple years ago, hardware for the TPI Intake. I purchased the kit. There were a coule that didn't match up as far as length, but I just cut those to make them work.
Thanks all! I went to my local tractor supply and found some stainless steel hex bolts. I seen that kit on eBay but I need the bolts as soon as possible. The only problem with the bolts I found is that one of the longer runner bolts is just a bit longer than the closest one I could find. It's maybe three threads off so should I not even try it or will it be ok?
