I'm getting digusted with it.
Old Jul 21, 2002 | 11:30 AM
poppy's Avatar
poppy
Cruise-In III Veteran
Default I'm getting digusted with it.
I thought it was fixed but it still makes a creaking sound in the right rear when I make a slow turn. More noticeable whengiving a little gas. Fluid and additive was put in and still no good. Then I had idle problems and cutting out problems on acceleration. I knew I was taking a shot in the dark when I bought a new MAF and last night while driving it, it just died. I coasted in a parking lot and wouldn not start. Then after a while it started and drove home as if nothing had happened. I have fairly new fuel filter, pump, coil, wires. Could I have water in the tank?
Old Jul 21, 2002 | 11:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: I'm getting digusted with it. (poppy)
Pull the codes to see if any help there.
Old Jul 21, 2002 | 11:39 AM
poppy's Avatar
poppy
Default Re: I'm getting digusted with it. (65Z01)
I reset the ECM when I installed the MAF and got no CHECK ENGINE after all this occured. Would there still be some codes?
Old Jul 21, 2002 | 12:10 PM
FoolCrzy's Avatar
FoolCrzy
Ignition Module inside the Distributor???? I had one that would stop working when it was hot...
Old Jul 21, 2002 | 12:21 PM
poppy's Avatar
poppy
Default Re: I'm getting digusted with it. (FoolCrzy)
Cheap enough. Sure couldn't hurt
To I'm getting digusted with it.
