i need some suggestions..
Old May 18, 2014 | 03:03 PM
lyndaolson's Avatar
lyndaolson
8th Gear
Default i need some suggestions..
i need a motor for my 86 .. does anybody have any suggestions or names i can go check out on the web .. i live in pahrump nv. an hour southwest from las vegas
Old May 21, 2014 | 02:11 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 1986
A brand new GM Chevrolet 350 engine would be my choice, comes with warranty.
Old May 22, 2014 | 10:02 PM
kmillar's Avatar
kmillar
If you want to go with a upgrade, contact Jim Barth aka 421tpivette. Good guy, he built my 421 and 396
Old May 22, 2014 | 10:48 PM
bassackwards's Avatar
bassackwards
I've been to Pahrump lots of times. Isn't there a brothel close by?
Old May 22, 2014 | 11:46 PM
gerardvg's Avatar
gerardvg
New GM engines are cheap and reliable, if you want to keep her fairly stock. There are also many crate engines that are very tempting.
Just check the rear seal before committing, i am pretty sure they went to a one piece rear main seal that bolted onto the back of the engine in 1986/87 onwards.
There 86 has early and late models, cast iron or aluminum heads. Hopefully someone can show a picture of a one piece rear main seal sump etc for easy identification, do not chose an engine until you know
what rear main seal type you have. Choose the correct replacement engine, the two types of engines do not interchange.
Old May 23, 2014 | 06:29 AM
WVZR-1's Avatar
WVZR-1
Unless you're very experienced and knowledgeable the last place for you to shop is the "web"!
You do need to determine what you have presently "first" - have there been any modifications previously?
Old May 23, 2014 | 06:59 AM
tunedport85inject's Avatar
tunedport85inject
one piece rear main 86>
two piece rear main 85<
summit racing has some options (stock engine)
http://www.summitracing.com/int/parts/nal-12499529
To i need some suggestions..
