86 low idle
Old May 21, 2014 | 08:07 PM
organcory's Avatar
organcory
Default 86 low idle
Hello, I am having an issue with low idle. It starts fine, and sits at a higher idle for a few seconds but then kicks down to really low idle, almost making it stall and sometimes it does stall. Of course its fine, if I keep giving it gas.
Old May 22, 2014 | 03:06 AM
Cliff Harris's Avatar
Cliff Harris
Try doing a minimum idle adjustment:
http://forums.corvetteforum.com/1570563689-post1.html
Old May 22, 2014 | 06:06 AM
organcory's Avatar
organcory
Seems easy enough, but I Have said that before... I will see what I can do.
Old May 22, 2014 | 09:58 AM
playsdixie's Avatar
playsdixie
cliff...this thread says nothing regarding disconnecting the dist wire also, as some threads do.....seems like that would make a huge difference when trying to set the idle....I've done it many times using the thread you've posted...with correct results....Paul..
Old May 22, 2014 | 10:00 AM
playsdixie's Avatar
playsdixie
I'd check the fuel pressure at the rail....might not be getting the right mixture..paul
To 86 low idle
