Maintenance / Replacement Schedule
In the USAF this was referred to as "mean time between failures".
Thank you.
At 90, probably the shocks are bad. If the charging/electrical system is good then don't worry about it, but eventually the alternator will go. Various sensors and relays will go but my MAF lasted forever without replacement, it is easy to replace but not cheap.
Wheel bearings and U-joints are the biggest expense that will come up.
my maf still going strong in my 85.....you'll probably need to look at new fuel pump/relays nearing 100,000 ..also injectors...if it runs good, drive it like you stole it......buy a fsm and join the crowd here....these guys will keep you going....Paul
Bleed the brakes until fluid until it is clean especially if the fluid is dark.
Flush the power steering fluid.
Check your break pads and parking break shoes.
Check the condition of your vacuum hoses and RR as needed.
The better you get to know your vehicle the better you will be able to take care of things before a problem arises.
If you leave the car standard it should be very reliable, there are some issues that need to be checked.
As the other posters have said, if you are going to keep her replace the fluids radiator and heater hoses including coolant (50/50 mix), serpentine belt and fuel filter.
The "star wars" dash has lights tend to overheat the electronics, be a good idea to replace them with the cooler running lights.
http://www.ebay.com/itm/Xenon-Bulb-Kit-C4-Corvette-Digital-Cluster-Gauge-Instrument-Panel-Gauge-Dash-/111360076709?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item19ed93eba5
The universal joints are a heavy wear item, all the power goes through them and they need to be checked. Clicking noises are the common sound when they have lost their grease and are about to fail.
The half shafts need to be checked, the universal joints closest to the brakes go first.
The early automatic transmissions tend to pop the front seal if you are doing a few quarter mile runs in a row, the later transmissions have retainers the seal clips on to.
Get a shop manual that will become your best friend with all the diagnostic stuff to help you fix any issues that may occur, the ECM will store codes that are easy to be retrieved and lets you know what is out of specification.
http://www.ebay.com/itm/1985-Chevrolet-Corvette-Shop-Manual-/191187392590?pt=Motors_Manuals_Literature&hash=item2c83a8184e
The TPI engines respond really well to headers, that is the best bang for buck.
Stay clear of "performance chips" they are a waste of money.
The brake pads need to be a high friction compound, corvette central have some hawk street brake pads that will make the car stop like it should. While on brakes the plastic brake booster tends to crack with all the engine bay heat, you can get metal copies so keep that in mind.
Oh do be carefull with the mirrors, the housings are bolted to the door and should you or anyone else accidently hit them against something they will damage the door before breaking away
Enjoy cruising around and getting good gas milage
Do not worry about the 190-230 cooling temp, that is where it is supposed to be for emissions.
