ABS dash light disable
Old May 26, 2014 | 05:03 AM
BOOT77's Avatar
BOOT77
Default ABS dash light disable
So what's the best way to disable my ABS light on the dash. Nothing is broke, it came on when I unplugged the relay and the unit will be removed.
Old May 26, 2014 | 12:50 PM
BOOT77's Avatar
BOOT77
Piece of electric tape it is! J/K
I assume there may be individual bulbs in that part of the dash? Or maybe a wire that I could cut?
Old May 26, 2014 | 01:14 PM
c4cruiser's Avatar
c4cruiser
There are individual bulbs in the DIC so that's one way to do it. But try disconnecting the wire harness at the ABS pump. That may shut the light off.
Why are you removing the ABS unit? That may require some changes to the brake lines.
Old May 26, 2014 | 06:07 PM
BOOT77's Avatar
BOOT77
I know their are many views and ABS is a good thing for many drivers. It's not my intention to start a debate. Pretty much gonna remove it for weight and to keep things simple. The car won't see ice or be driven in the rain.
Old May 26, 2014 | 07:48 PM
hcbph's Avatar
hcbph
Default Thought
Remember if you pull the ABS pump out of the car, you're likely going to have to replace it with a proportioning valve or expect daily spins in certain conditions.
Old May 27, 2014 | 12:30 AM
Cliff Harris's Avatar
Cliff Harris
Pull the ABS fuse.
Old May 27, 2014 | 02:38 AM
BOOT77's Avatar
BOOT77
Originally Posted by Cliff Harris
Pull the ABS fuse.
Thx again Cliff I'll pull it tomorrow.
To ABS dash light disable
