I am putting on 245/40z/r18 front and 285/35z/r19 rear on a 1992 c4 coupe. I need to know for sure if I need spacers or not. I've found lots of info but nothing exact to my car
2nd do I need hub centric or lug centric spacers?
Jack
Reason: Additional info
The C6 OEM tire sizes are taller than the stock tires on the 91-96 C4 Vettes.
That's why I suggested the other tires sizes.
I have the 19x10 C5 Vette Deep Dish wheels and I found that the 285/30/19 tires are just about the same diameter as the stock 275/40/17 C4 tires. According to my GPS App, the speed at 65 mph matches my speedometer display.
Using C6 OEM tire sizes, the speedometer will show a +3mph increase at 65mph.
Actually, 245/35/18 front and 285/30/19 rear would be the closest match to the stock C4 275/40/17 tire height.
Also, the C6 OEM 19x10 wheels have a 79mm offset and the Aftermarket C6 wheels have a 68mm offset so, it depends on what C6 wheels you have which will determine the correct spacer or adapter size. The OEM C6 wheel will require a 20mm (or 3/4") adapter.
Also, the C6 OEM 19x10 wheels have a 79mm offset and the Aftermarket C6 wheels have a 68mm offset so, it depends on what C6 wheels you have which will determine the correct spacer size. OEM C6 wheel will require a 20mm spacer.
