Brake makes hissing noise ?
Old May 29, 2014 | 01:41 PM
drenfree1's Avatar
drenfree1
Cruising
Default Brake makes hissing noise ?
Just put new pads on front ( 93 ) know I have hard pedal and vacuum noise just when I step on the brake. I have done the test to check power boost and it passes all..?? The one thing different is when I turn the engine off with foot on the pedal...it gets really hard..and it comes UP about 1 inch.????? Any ideas. ..
Thanks for any help...
Old May 29, 2014 | 05:01 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I'd say the booster diaphragm is torn.
Old May 29, 2014 | 05:29 PM
drenfree1's Avatar
drenfree1
Cruising
[QUOTE=Black89Z51;1587012433]I'd say the booster diaphragm is torn.[/QUO
Thanks for the reply..i was thinking the same but i have a great brake on the first push of the brake then after that, each one gets harder.
does that sound right ??
i do have the one way bleeder valves in so after i put the new pads in i just gave each side in front ONE push of the pedal to bleed them. power unit was fine until that ???
Old May 29, 2014 | 07:57 PM
gerardvg's Avatar
gerardvg
[QUOTE=drenfree1;1587012681]
Hi
The same thing happened to me TWICE!! after bleeding the brakes, was fine before and i replaced the brake pads and replaced the brake fluid and the booster diaphragm failed. Had a hissing sound afterwards and had to replace the booster.
Seems that the extra travel when bleeding the brakes tears the old diaphragm
I gravity bleed the brakes now, i do not want to take my chances.
Old May 29, 2014 | 08:06 PM
drenfree1's Avatar
drenfree1
Cruising
Default Thanks
[QUOTE=gerardvg;1587013668]
Originally Posted by drenfree1
Hi
This sounds the same as what i did...i just sent for another unit and will do the gravity bleed this time...Thank's again for your help..
To Brake makes hissing noise ?
