The car is not shifting right. It goes from first to second and stays there unless I take my foot off the gas. Then it goes to third. But as soon as I give it gas, it jumps back to second. Accouple of weeks ago it wasn't going into overdrive. It's definitely getting worse. Any thoughts? I had my trans flushed and new filter last year.Fluid level seems to be fine.
Also, check the "Throttle Position Sensor". They can go bad and do really strange things to a transmission shift pattern. It's an easy sensor to check.
