90 Engine vibration
Old Jun 3, 2014 | 03:31 PM
Ron Serne's Avatar
Ron Serne
6th Gear
Default 90 Engine vibration
I have a 1990 L98 convertible with 84,000 mi that I have owned for 10 years.
Last year the car developed a vibration at about 3500RPM which rattled the reverse ring so bad I thought it was going to come off.
The clutch began to slip and the release bearing got noisy so I replaced clutch, pressure plate, release bearing, and pilot bearing. The dual mass flywheel was in good shape, smooth, no defects, so was buffed up and clutch replaced.
The vibration continues and seems to come from the engine.
The vibration occurs at 3500 rpm in any gear, out of gear , stopped, in neutral, clutch in or out.
Harmonic balancer? motor mount?
Any help would be greatly appreciated!
Old Jun 3, 2014 | 04:25 PM
Hooked on Vettes's Avatar
Hooked on Vettes
If you manually operate the throttle body linkage and rev the engine can you see
the engine vibrate or move.
You could also remove the serpentine belt and see if the vibration goes away. Could be one of the accessory brackets is cracked, bad tensioner, AC compressor pulley, alternator bearing etc...
The water pump wont be operating so don't do this test on a hot engine
For a balancer problem, disconnect the Brown wire going to the distributor so the computer can't advance the timing . Use a timing light and verify the timing is 6 degrees BTDC. If the timing is off it could indicate the balancer is separating.
Old Jun 3, 2014 | 06:14 PM
jv9999's Avatar
jv9999
Check the motor mounts? Put some torque on the engine (parking brake on, 1st and reverse) and see if the motor moves.
Old Jun 4, 2014 | 06:24 PM
leesvet's Avatar
leesvet
balancers DO slip and come apart !
I had one actually separate and I got a strange vibration out of nowhere and was baffled....
also, when I shut it down, I would hear this dinging noise for 10 seconds AFTER shutdown....metallic and ongoing even after the engine stopped turning. I FINALLY got under the hood and had someone else shut it off....and spotted the outer ring of the balancer spinning on the inner hub !
if you can see ANY dry-rot or rubber edges cracking around the edge of the balancer ring....go find a new one...its on borrowed time.
Old Jun 5, 2014 | 10:40 AM
Ron Serne's Avatar
Ron Serne
6th Gear
Thanks for all the help!
Not having a lot of time I had a quick look last night and discovered a nut missing on an A/C brace.
I installed a new nut and then discovered that the vibration goes away when the A/C is switched off but comes back when I turn on the A/C.
I will check out the A/C pump.
Thanks again
Old Jun 5, 2014 | 01:51 PM
leesvet's Avatar
leesvet
Get a light and L:OO:K <----- real close at the a/c bracket ! Those crack real easy behind the compressor and below where the tensioner is....
Ya gotta have ALL the nuts/bolts in the a/c bracket AND the braces! especially the braces. Some have 2, others have only one to the ex manifold.
Fortunately they make new brackets now....they ain;t real cheap but they can be had.
To 90 Engine vibration
