Fuel tank sending units
Old Jun 5, 2014 | 10:34 AM
ANTI VENOM's Avatar
ANTI VENOM
Default Fuel tank sending units
Does anyone know if you can buy just the "resistor" part of the sending unit. Should be 0-90 ohm like a million before it. I'm looking for the insulator with the wire wrapped around it. Can't find one.
Old Jun 5, 2014 | 01:42 PM
WVZR-1's Avatar
WVZR-1
This fellow can help. I spoke to him about purchasing for an export since the ship of the unit to be repaired wasn't practical. He doesn't normally but he may. It's worth the time to ask and discuss what you've got in mind. Years ago this wasn't an issue I could buy them easily, then we cannibalized tank units for just the rheostats and now they're done just a bit differently so the units to cannibalize have disappeared.
http://tristarrradiator.com/index.html
I haven't looked recently any further than just this fellow. I've spoken to people that have used his services and all were happy so I didn't look any further. I might do it again though.
Try using "wiper" or "rheostat" in your searches - that should help.
Old Jun 5, 2014 | 01:46 PM
leesvet's Avatar
leesvet
Not a chance, IMHO
There is no point when the whole assy is only $175 (sometime less) new.
even IF you could replace one, then you have a calibration problem. Just because the float arm will read ZERO at one end of the scale does not mean that is where the fuel level will be and the tank is not symmetrical, so the level equivalency changes each inch of fuel...
I've replaced many senders in C4s and its unbelievably easy to totally mess up the gauge...brand new cars will read accurately to the last mile/gallon. Pull that sender and bump it once....never see that accuracy again.
Old Jun 5, 2014 | 03:50 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by leesvet
Not a chance, IMHO
I'm sorry but it's been done for years by many and done quite well I could add. You failures are may be "self inflicted"!
Old Jun 5, 2014 | 05:13 PM
ANTI VENOM's Avatar
ANTI VENOM
Thank you WVZR-1. I'll check into it.
Lee? I'm not sure what you are doing, but in this case, you just pull the insulator with the wire wrapped around it, out and replace it. Nothing will move. NOTHING...
Now, in all honesty, the unit I'm referring to is NOT on my vette. It is a GM however. I thought they were all very similar with the 0-90 ohm. This unit is out of an 89 Chev BBC truck. I have another unit that works, but the reading is all over the place.
Old Jun 5, 2014 | 05:38 PM
WVZR-1's Avatar
WVZR-1
Two different '89 trucks - this is a CK truck or an RV truck? CK no door vent window, RV has a door vent window.
Old Jun 6, 2014 | 02:30 AM
Cliff Harris's Avatar
Cliff Harris
The same 0-90 ohm fuel level sending unit element was used in MANY GM cars for MANY years. I have been searching for a source for these guys for a long time without success. The fancy stainless steel sending units you can buy now have a new sending unit, so obviously the manufacturers are getting them from somewhere.
Newer cars have a completely different modular sending unit element, which you CAN buy, but they don't fit our cars.
Old Jun 6, 2014 | 09:26 AM
ANTI VENOM's Avatar
ANTI VENOM
Originally Posted by wvzr-1
two different '89 trucks - this is a ck truck or an rv truck? Ck no door vent window, rv has a door vent window.
1989 v30
Old Jun 6, 2014 | 09:43 AM
WVZR-1's Avatar
WVZR-1
1989 v30
A correct tank unit (less pump) can be done for likely less than $70 for your truck. Might make a slight difference for right or left side but it's not outrageous by today's standards. I believe you want to shop Spectra by brand. Years ago all of the Spectra product was Canadian construction and I used a good bit of their product. Today I'm sure the sourcing has changed.
Old Jun 6, 2014 | 10:05 AM
leesvet's Avatar
leesvet
This may be true,
but HOW can you replace an integral part of that assembly without somehow altering the accuracy of the sender as an assembly?
Now for example, mine shows empty when there is actually a cpl gal remaining. That's a replacement assembly too. Its just been handled several times and each time the gauge reads a little different than before...
I've done this repair/replacement and every time the gauge was nowhere nearly as dead-nuts, spot on precise as it WAS..........
To me, (not totally OCD either) the accurate fuel level was the point of the repair, if that was disturbed, that negated the repair process.
I realize that, in theory at least, that as long as the float arm is not bent, damaged or tweaked that the sender should end up with the same ranging as it did before....but it don't !
I dunno....I've got a couple sender assys that I might revisit and gather some boneyard parts and TRY to do this and discover what can be done to assure an accurate gauge post repair.
To Fuel tank sending units
