Fuel injectors on 85
it's kind of hard to give you a step by step procedure here - all you need is a bit of common sense, and some technical know how. replacing the injectors you can either clean the first generation bosch (which BTW are a decent injector), or replace them with rebuilt boschIII's. Jon @ FIC can set you up with either the cleaning service, or the boschIII's, along with any gaskets, and other service items you'll need.
if and when you run into an issue, keep this thread open and post a how-to question. plenty of members here with a lot of hands on experience.
This is also a great time to remove the intake manifold and re seal it as it will eventually leak.
Purchase a long torx bit with a 3/8 drive as it will come in very handy. Also think about going to a place such as Fastenal with your runner to plenum bolts and buy some with hex heads. Then purchase a ball tip long extension in the correct size to help with your install. This will make your job go much easier.
Take pictures as you go and once again I will add to the above advice - replace those fuel rail O rings! You don't want those old, hardened ones in there under high fuel pressure.
A tip on releasing the clips that hold the fuel injector wiring to the injectors. Just push in on them and that will release the connectors.
I took the black plastic wire covers off and covered the wiring with split, colored plastic conduit (blue to match my plug wires) and thought that made things look a bit neater. Mine is a 91:
Good time to clean the throttle body, replace the thermostat, do the throttle body bypass mod and clean up and respray the plenum, runners, manifold and valve covers. Might as well clean the crud between the radiator and AC condenser and rent a pressure washer to clean up the engine bay. Well worth the time and effort.
And (this could go on forever) replace the water pump, flush the radiator and block and install new hoses. New spark plugs and wires too! Rebuilt distributor time?
Be sure not to let your significant other see the receipts for all the parts either
These type of projects have a way of morphing into a blown 383 with aftermarket heads, headers, cam and performance intake.
- been there, done that - TWICE!
BTW, here's a couple of "specialty" tools I mentioned in my previous post. aside from the standard 3/8th drive torx socket set, I bought a 3/8 drive T40 that's about 6 inches long, and I RTV'd together a T40 bit into a 1/4" drive X 1/4" swivel socket. found both extremely helpful in removing the plenum.
here's my latest - started out fixing an oil leak, and ended up with a corsa cat-back, with lots and lots of stuff in between -
Be sure to talk to John Banner at Fuel Injection Connection in Cummings, GA to purchase your replacement injectors or better yet, have your OEM injectors rebuilt and balanced.
P.
Yes contact Jon Banner at http://www.fuelinjectorconnection.com
They are THE BEST !
Without the clips holding the injectors in the fuel rail and without the extra o ring at the bottom of the injector the fuel pressure tends to push the injector down into the inlet manifold and can cause a leak.
It did it on a couple and i managed to fit the clips and that worked fine.
(That was before i found out about the extra O rings so they do not get pushed down into inlet manifold)
I now know FIC uses two o rings on the base of the injectors and one on the top, where is the original injectors the body hits the manifold and never bottoms into it.
I recommend you replace the fuel pressure regulator diaphragm, and fit the fuel rails and bolt them down have the runners in place but not bolted down yet . Then fit the fuel pipes and test the fuel injectors by turning the ignition on before assembling the runners. Is a pain to have to the job twice.
