1996 LT4 - won't start when hot
Old Jun 11, 2014 | 11:36 PM
vette442's Avatar
vette442
Default 1996 LT4 - won't start when hot
Hi all - I did a search through the archives and saw some threads that were somewhat similar, and many had no resolution.
My '96 LT4 with 35k miles (no mods, owned since 3k miles) runs perfectly fine, but if you shut it off when hot, the odds are good that it will not restart. It will crank away but won't start. If you let it sit for 20-30 minutes it will start right up and run like nothing ever happened.
Last fall it did this to me during a long road trip, but last week it did it after only a 5 minute drive. Again, no missing or hesitation while driving, and it will start right up after cooling down for a while. The only anomaly is that once last fall it did restart and run rough for a couple seconds before dying, then I let it cool down before trying again and it was fine.
Suggestions appreciated. I'm figuring it's something fuel related or the electrical system that serves the fuel system getting hot.
Thanks in advance -
Terry
Old Jun 12, 2014 | 11:58 AM
vette442's Avatar
vette442
Failed fuel injectors?
(I'm looking at LT4-specific Bosch ones from FIC if I need to replace these)
Coil?
Was hoping someone else would have come across the same issue.
Terry
Old Jun 12, 2014 | 12:15 PM
BBNJKen's Avatar
BBNJKen
Terry;
When the wont start, does it throw any codes?
Nice car BTW..
Old Jun 12, 2014 | 12:22 PM
wydopnthrtl's Avatar
wydopnthrtl
In the old days that would be perfect symptoms of a bad coil.
Old Jun 12, 2014 | 12:30 PM
vette442's Avatar
vette442
Thanks for the responses so far. We're trying to reproduce the issue this afternoon and have a code scanner handy. I'll provide an update when something turns up.
Terry
BBNJKen's Avatar
BBNJKen
Hey Terry;
When it doesn't start, does it:
1. Have spark at the plugs.
2. Have "normal" fuel pressure?
To 1996 LT4 - won't start when hot
